X-Type has Small buzzing in cockpit when keys are not in column.
Old Sep 8, 2016 | 10:17 AM
Typo_Caps_Bot's Avatar
Default X-Type has Small buzzing in cockpit when keys are not in column.
Is this normal or Common....My jag had a low level buzz/hum when its not turned on or keys in ignition...It does affect the battery or seem to get hot, but I am slightly concerned bout this before winter. As almost all issues I have had with cars electrical really are exagerated come winter time here in upstate/Albany NY area, our temps can drop to negative -25 below 0 F.
Can it be the antitheft? but I always hear it ,Car has only 56k miles its an 03 X-Type 2.5 automatic....The sound/buzz seems to be in the dash area so what can it be,should I worry?
Thanks folks Hope to hear back soon.....
Attached Thumbnails X-Type has Small buzzing in cockpit when keys are not in column.-win_20160908_10_35_05_pro.jpg
Old Sep 8, 2016 | 10:48 AM
Thermo's Avatar
Veteran: Navy
Typo, the noise is coming from the right side of your steering column. If you look to the right of your steering column, you will see a very small vent (about 1x1" in size). If you put your ear near there, you will hear the buzz coming from there. That is a little fan that pulls in the interior air to determine what the interior temp is. This information is then sent to the A/C unit to maintain the interior temp.
This will run any time the door is open and for about 15 minutes there after. This has no negative effect on the battery or your ability to start the car. A normal part of the car.
Old Sep 8, 2016 | 11:29 AM
motorcarman's Avatar
Do you realize how many times I had to argue with customers about the stupid air aspirator/temp sensor?????
It will shut off eventually but people SWORE it never shut off.
bob
Old Sep 8, 2016 | 12:35 PM
Thanks so much gentlemen..thats awesome...I figured it was no biggie as my battery was always fine...But thats so cool to get a reply so fast...Thanks again.....
Old Sep 8, 2016 | 05:33 PM
sov211's Avatar
bob
People swear that the aspirator fan runs all the time because every time they open the door to check, sure enough, it is running! What no one has told them is that this fans starts running the instant the door handle is pulled and remains running until about 15 minutes after the engine is shut off - unless someone pulls the outside door handle again.
Perfectly normal. If anyone has an issue with this it is the Denso people who designed the system that should be consulted. Denso engineers the climate control systems also for Lexus and other high end cars, not just Jaguar.
Old Mar 16, 2018 | 04:41 PM
BudL1te's Avatar
This may be what I came looking for. I will check that vent. Thank you.
daddylogan
Sep 15, 2016 01:50 PM
geekman
Sep 14, 2016 10:41 PM
MikeofBonsall
Sep 10, 2016 10:44 AM
smgdata
Sep 7, 2016 11:14 PM
Ubad2
Sep 4, 2016 09:54 PM
