x type headlight fault
Old Sep 30, 2013 | 03:39 PM
chris haden 57's Avatar
Default x type headlight fault
hello....i have a 2005 x type 20D the headlights dont work on either dip or headlight...allthough the headlights work ok on the flasher stalk,,,,side lights and front rear fog lamps work as should......iv tested with multi meter every fuse in both units..and tested and changed some relays.....finaly got to the point of changing the light switch....and still no joy.....has anybody please got any idea as to what to try now as im fair out of options......my thanks in anticipation...chros
Old Oct 1, 2013 | 04:18 PM
astromorg's Avatar
If the main beams work on flash, but not when selected for continuous use, that suggests that the dip/main beam selector switch on the steering column is U/S.
For the dip beams, if the fuses are good and the switch is new, then assuming all the wiring connections are good, that leaves the relay or the bulbs themselves. The earth connections are shared, one to each pair of light units, so as the main beams flash, they're OK. Have you checked the bulbs and tried a new 4 pin relay?
Old Oct 1, 2013 | 09:59 PM
Thermo's Avatar
Veteran: Navy
Chris odds are, for your dip beams, your relay is toast. Granted, there are 2 fuses for the dip beams that could also be the issue. I do not have my diagrams in front of me, so, maybe someone else can give you the fuse numbers to check. The two fuses are the main power for the dip beams and the power for the relay switch actuation. Either one of those can give you the symptoms you are seeing.
Old Oct 2, 2013 | 06:43 AM
Default headlights
my thanks to the two gentlemen for their help..i will endevour as soon as it stops raining....this is wales..! and will come back to you asap..thanks again gents
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
David Thompson
Sep 3, 2015 07:48 PM
pnwrs2000
Sep 3, 2015 11:55 AM
dcvickers
Sep 2, 2015 06:14 PM
