X-type jaguar 2006
Old Nov 9, 2019 | 03:20 PM
Pauldengland's Avatar
Default X-type jaguar 2006
Hi everyone,
I have recently acquired a 2006 Jaguar xtype. The Sat nav screen screen is blank and although the radio works (you can turn it on and off) nothing on the media system works and the fans (interior) are stuck on.
any ideas?
thanks
Paul
Old Nov 9, 2019 | 06:24 PM
Thermo's Avatar
Veteran: Navy
You will need to replace the radio. A local recycling yard should have a new radio. Just, make sure to get a statement from the wrecking yard that you have bought the radio from a wrecked car as you may need to input a code and the only way to get the code is to go to Jaguar and they will need the VIN from the other car (not yours) and you will need to prove that you bought the radio legally.
Old Nov 10, 2019 | 01:14 AM
thank you 👍
Old Nov 10, 2019 | 01:39 PM
edtoo's Avatar
Originally Posted by Pauldengland
Hi everyone,
any ideas?
thanks
Paul
Do you have the premium or standard sound system? The premium has Alpine speakers and an amp in the trunk. If you have the standard system then the radio will work independently of the D2B circuit (Fibre optic) in which case you have an unterminated connection on the circuit. This could be something that has been removed, a plug that has fallen out of a device that has failed for example the CD Changer. The Satnav won't show anything if the D2B circuit is broken.
hlotero
Nov 20, 2018 05:53 AM
hlotero
Nov 18, 2018 07:03 AM
backrow pupil
Sep 12, 2016 07:25 AM
butch h
Dec 21, 2013 08:25 AM
juliesjag
Aug 27, 2011 01:11 PM
