X-Type leaking water???
Old Aug 5, 2014 | 08:52 PM
ChelseaFC2014's Avatar
Default X-Type leaking water???
Hi everyone,
I own a 2007 X-type with 108000 km on it. My AC has not been working properly lately. It blows warm air when the car is idling and starts to blow cold air at higher revs. When I slow down or stop, the warm air is back. In addition to that, when I park the car, a pretty substantial puddle forms underneath the front of the car. The liquid is transparent and has no taste so it must be water. Where is it coming from? Is it condensation from the malfunctioning AC and how do I fix this? Any help or advise would be greatly appreciated.
Old Aug 6, 2014 | 03:11 AM
Petri Alvinen's Avatar
Originally Posted by ChelseaFC2014
Hi everyone,
JTB00183 (http://www.jagrepair.com/images/TSB/...AS1%5B1%5D.pdf)
-p
Old Aug 26, 2014 | 09:39 PM
gazza836's Avatar
Hi everyone,
Hi,
It sounds like you are accumulating water in your plenum chamber.
The drains get blocked easily due to there being some sound deadening foam stuffed up between the front wings and the 'A' pillar area.
I would remove the foam padding and throw it away as it is only to reduce wind noise and to be honest I haven't noticed any difference with it removed.
Hope this helps
Gary
Old Aug 27, 2014 | 08:54 PM
Meouch's Avatar
wait. you tasted the liquid to determine if it was water? BRAVE!
Old Aug 28, 2014 | 02:17 AM
Meouch's Avatar
Have you checked for a plugged cabin filter?
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Saturbo
Sep 8, 2015 07:35 PM
Whitnessmouse
Sep 4, 2015 11:09 AM
