X Type P0305
Old Jul 28, 2020 | 08:05 AM
ken736cc's Avatar
Default X Type P0305
Hi,
I have a 2002 X Type sport 2.5. I have been chasing a P0305 code (misfire cyl #5 ) for a while now. Here is where I am at: Ignition coil, spark plug and fuel injector have been replaced with new. I can use a scan tool to delete the code and all seems well until I drive about 75 miles. I drive the car about 20 miles a day. The code will re appear about 30 seconds after a cold start. I can clear the code and repeat this process.
I am due for NYS inspection in August and cannot have a check engine light. . I am interested in hearing any ideas or theories as to why I can drive for a while and then get a code. Thanks
Old Jul 28, 2020 | 10:56 AM
Thermo's Avatar
Veteran: Navy
Ken, I would be looking at the wiring for the coil. Odds are, the ground wire between the #5 and #3 coils has an issue and will most likely need repaired. You have done the obvious. Now we are getting into the more obscure problems.
Old Aug 14, 2020 | 09:45 AM
ken736cc's Avatar
Hi,
By chance do you know the wire colors for power and ground for the coils and fuel injector? I will be trying this solution this weekend.
Ken
Old Aug 14, 2020 | 11:29 AM
Thermo's Avatar
Veteran: Navy
Ken, I iwll do one better, PM me your e-mail address and I will send you the whole electrical diagram for your x-types. That way you have all the info that you need.
Old Aug 17, 2020 | 08:58 AM
ken736cc's Avatar
Hi,
Thanks for the diagram.
Coil ground appears to be the black wire. I will add an additional ground. Does anyone know why the coil has 4 wires? I am waiting for a new injector connection with a pigtail. I am desperate to pass inspection without a check engine light. I am thinking of adding a switch to turn off cyl 5 injector until I pass inspection. This is probably a crazy idea.
Old Aug 17, 2020 | 12:28 PM
Thermo's Avatar
Veteran: Navy
Ken, the coil has a primary coil that is hard wired to 12 VDC that builds up a field in the coil. The other 2 wires are the signal that redirect the output and sends it to the spark plug. The coil attempts to maintain the current flowing through the coil by collapsing the field. Because you have a high resistance (ie, the gap of the spark plug, the field collapses really fast and generates a high voltage to bridge that gap. That is how the spark is generated.
Old Aug 17, 2020 | 01:19 PM
ken736cc's Avatar
Hi,
Thanks. That makes sense now. I am trying to understand how the ECU can detect a misfire and identify the exact cylinder.
Old Aug 18, 2020 | 01:36 PM
Thermo's Avatar
Veteran: Navy
Ken, it is watching the up stream O2 sensor. It is watching the voltage. The computer knows that so many milliseconds after a cylinder fires the exhaust gases will pass the O2 sensor. You match up when little spikes happen at the O2 sensor, you can figure out which cylinder is not firing correctly. This is why sometimes you may get multiple cylinders misfiring, but really only 1 is.
Old Aug 19, 2020 | 12:53 PM
JagV8's Avatar
It can watch the crank and see when it doesn't move as it should. That's why you have to do coast downs to set the appropriate monitor(s).
Old Aug 22, 2020 | 11:03 AM
ken736cc's Avatar
Success! I replaced #5 spark plug, cleaned all connectors and replaced the connector on Cyl 5. Check engine lite is gone. It took 70 miles of driving for the computer to complete the inspection ready tests. I did 3 coast down fron 70mph to 10 mph plus 5 miles of 35mph driving. State inspection good for 1 more year. .!
Thanks everyone.
Old Aug 23, 2020 | 11:20 AM
JagV8's Avatar
Excellent!
Chris1971
Jan 16, 2021 01:36 AM
Simon99
Mar 11, 2020 03:20 AM
ugotmale
Mar 5, 2019 07:26 PM
Wahooesprit
Nov 2, 2015 01:53 PM
Poet
Oct 28, 2015 06:25 AM
