X-Type Pulling Left at Lower Speeds
Old Feb 14, 2014 | 02:38 PM
bdevenyvm's Avatar
Default X-Type Pulling Left at Lower Speeds
My X-Type is pulling left at lower speeds. Above 65 mph it pretty much straightens up. The slower I go, the more it pulls. But, it brakes straight.
I have had the alignment checked -- no problem. Replaced a bad right strut and knuckle. This started when I changed wheels and tires. I know that the inside rim of the right rear tire is slightly bent and plan to have all the wheels straightened and trued. Is it possible that the right rear wheel is the culprit? Anything else to check?
Old Feb 14, 2014 | 03:06 PM
Jac's Avatar
Jac
I would check your tire pressure.
Old Feb 14, 2014 | 04:24 PM
Thermo's Avatar
Veteran: Navy
Tire pressures could possibly do it. But, I would also see if you have a brake caliper that might be hanging up a little bit and it is putting excessive drag on that one side and once you get up to speed, the grip of the non-sticking side helps it straighten out.
Old Feb 14, 2014 | 05:48 PM
MarkC's Avatar
Originally Posted by bdevenyvm
... This started when I changed wheels and tires. ...
There you go.
If the tires are not directional, try rotating them side to side to see if things change. Sounds like a bad tire.
Old Feb 15, 2014 | 02:09 PM
Ants2505's Avatar
I had the same problem. I put brand new bridgestones on and it transformed the car
Old Feb 16, 2014 | 01:54 AM
bdevenyvm's Avatar
Thanks, everyone. The tires are directional, but seem to be mounted properly. I will give all that a try.
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
PMKimpton
Aug 3, 2019 08:22 PM
mikelibera
XJ40 ( XJ81 )
Sep 4, 2015 05:17 PM
Whitnessmouse
Sep 4, 2015 11:09 AM
