X Type Tailgate Glass Catch Releasing
Old Mar 6, 2010 | 09:08 AM
Real_Tech's Avatar
First lets make sure we are talking about the same thing. You are saying that the glass only pops open when you switch the car to run. The button to open the glass by itself is located on a small finger tab where the wiper is located. Take the wiper/handle/button assembly apart and look for a pinched wire for the switch. I've seen this many times. The module responsible for activating the release will shut down the release function when it senses the button being held down constantly. When you shut the car off for an extended time the module resets and then when you turn the key on it will open the glass but then disable the opening again when it finds the button constantly pressed. Look especially close where the wiring leaves the handle area. It passes through a tiny opening that appears to be too small and the wires chafe there.
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
KarimPA
Sep 3, 2015 07:32 PM
dcvickers
Sep 2, 2015 06:14 PM
XFR_Gold
Sep 2, 2015 12:24 PM
