x type tranny
Old Jan 10, 2014 | 11:21 PM
cyclesmith's Avatar
Cool x type tranny
My jag was not shifting properly and had a whining nose sometimes i drained the oil from the transmission and measured it approx 7 quarts then replaced it with Castrol wulti vehicle transmission fluid drove it for 3 weeks and did it again it has been 3 months and it works perfect. no more hesitation or whining
Old Jan 11, 2014 | 03:11 AM
Pete,
I've moved this second post of yours from New Member Area - Intro a MUST to X-Type forum.
Transmission noises are often a cause for concern to members and it's always good to hear of a successful resolution.
Old Jan 11, 2014 | 05:11 AM
rclangelan's Avatar
After draining 7 quarts, did you put exactly 7 quarts back in? What viscosity?
Did you find the drain/refill process to be particularly difficult?
Thanks.
Old Jan 11, 2014 | 09:44 AM
Harleychris1969's Avatar
From what I have read on here that's about 3.5 quarts to much. I drained mine got about 3.5 to 4 quarts. My guess you have to much tranny fluid in the transmission. Good luck. Let's know what u find out.
Old Jan 12, 2014 | 06:38 AM
cyclesmith's Avatar
I measured and put the exact same amount back in. \\this is the first time I have had the plug out of the transmission so if it is over filled then it has been for almost 4 years that i have had it. Hugh difference now has no hesitation when stopping and restarting quickly.
Old Jan 12, 2014 | 06:07 PM
AlfaVeloce's Avatar
I used the Castrol Import Multi vehicle as well. Good stuff. I set the level by warming the transmission to 100deg F or so (don't remember the right number) and removing that small hex key plug near the gear selector attachment. Level is correct when fluid just quits coming out the drain.
I agree on 7 being too much from what I have read here on this board. More like 3.5 quarts should come out of the main drain plug. Too much fluid in the tranny will cause hella noise for sure.
way2far
Aug 31, 2022 09:26 AM
ZJag
26
Sep 5, 2016 03:33 PM
raffoulig
Sep 8, 2015 01:56 AM
KarimPA
Sep 3, 2015 07:32 PM
dcvickers
Sep 2, 2015 06:14 PM
