X type Trans swap 2006 into 2002 DTC codes 61165-61175
Old Oct 3, 2012 | 07:02 AM
xkecoupe's Avatar
Default X type Trans swap 2006 into 2002 DTC codes 61165-61175
I installed a 2006 automatic trans into my 2002 x type with 3.0 engine. My car is the early version on the vin #. Trans works fine but my speedo doesnt work and my abs light is on. DTC fault codes from my basic code reader are 61165 and 61175. I have never seen a code starting with 6 before. I was thinking that the trans module out of the 06 might correct the problem. Any ideas if this will help or what the codes stand for??
Old Oct 3, 2012 | 02:16 PM
disguay's Avatar
I have never seen a code starting in a 6 before either. I have also never seen a 5 number code either. All jag codes I'm familiar with are shown in this way A####. Maybe your code reader thinks that 6 stands for a letter? If I were you, I would go with the new tcu, but I would read the codes first before you pull the trigger just to make sure everything else is going smoothly
Old Oct 4, 2012 | 08:05 AM
xkecoupe's Avatar
Funny thing about the code reader is it shows the P1000 code before the 61165 and 61175. it works fine on other cars..weird. I tried to buy the TCM from car I got motor and trans but it was gone. Looking elsewhere now. By the way your car looks like a carbon of mine. thanks for the input
stanjag
Dec 29, 2024 08:26 PM
montypeek
Sep 6, 2015 04:57 PM
easylender
Sep 1, 2015 12:56 PM
roumor
Aug 28, 2015 01:02 PM
brent65622
Aug 26, 2015 08:41 AM
