x type uneven tyre wear
Old Mar 4, 2011 | 04:16 AM
ImranR's Avatar
Default x type uneven tyre wear
Had rear tyres changed. Put on Pirelli 205 55 V16 - J : specifically made for this Jag. They have worn out on insides within 6000 miles and 7 months.
Any ideas why?
Old Mar 4, 2011 | 07:12 AM
Racer Ronnie's Avatar
Smile Inexpensive diy fix.
I had the same problem...
1. New tires => No help.
2. Two realignments => No help.
3. $15 Coil Spring Spacer => 'Even' tire wear for the past 1.5 years with the same tires. The adjustable Coil Spring Spacers are do-it-yourself easy installation, which re-level the rear end. http://www.discountautoshocks.com/in...3RhbGxhdGlvbi4=
Also, I recommend Fuzion/HRi tires; they can be rotated in a criss-cross pattern for more even wear of all four tires.
Old Mar 4, 2011 | 05:39 PM
Thermo's Avatar
Veteran: Navy
Imran, check your lower forward suspension arms. I bet you will find some worn bushings on the inside bushing (attached to the frame of the car). This is a common problem with our cars. The new arms are around $100 a side and take about 30 minutes to install per side. 2 bolts and the arm comes out. Keep in mind that you will also end up getting another alignment after this is all done.
Old May 22, 2011 | 03:15 PM
Bdouble's Avatar
Thermo sounds right on this one. Rear alignment can be tricky on this vehicle as I have had issues as well. I would bring the vehicle to a shop with quality equipment such as as Hunter machine and qualified technicians. Once car is aligned properly inner wear should disappear until then you will be spending a fortune on tires.
Old May 23, 2011 | 04:12 AM
ImranR's Avatar
Default uneven rear tyre wear solved
Thanks for the suggestions, but I am no mechanic.
Took it to Racing Green Cars in Ash, Hampshire and they changed rear control arms before doing a proper 4-wheel laser alignment. Total cost around £400.
So far, so good.
Old May 23, 2011 | 08:26 AM
pab's Avatar
pab
Yup, same thing...
When I had my X-Type at the dealer for a bunch of stuff (coolant flush, thermo replacement, brake fluid replacement, transfer case replacement... =:-0
They told me that my rear bushings were worn and the rear alignment would no longer be correctable. They told me it would cost around the same amount ($600) to fix. I deferred at that time...
My karma just ran over your dogma
'05 Jaguar X-Type
Old May 23, 2011 | 08:27 AM
pab's Avatar
pab
Oh, 62,000 mi (or 100K if you measure that way... ;-)
way2far
Aug 31, 2022 09:26 AM
PMKimpton
Aug 3, 2019 08:22 PM
ZJag
26
Sep 5, 2016 03:33 PM
KarimPA
Sep 3, 2015 07:32 PM
dcvickers
Sep 2, 2015 06:14 PM
