X-type - very strange ??
Old Mar 3, 2014 | 11:48 PM
magicjuan17's Avatar
Default X-type - very strange ??
We'll had my Xtype for over. Two yrs no issues but spoke to soon -
Today driving my car through out the day when I tried to reverse the car raved up but no movement like if it neutral - I reset it - check ECM - checked TCM it drive great in drive 2gear 3rd & fourth - no issues but no reverse - now here's the stranged thing no codes - I'm pretty sure this issue my car would be flashing gear fuslt codes but no car looks & sound feels normal but won't go into reverse -
Now I did resheached on this & %99 said it was due to losing a bolt by Trans - I never losen any bolt except oil drain which is no where near the bolt there taking about - I haven't been under my car for months - now I did drive over hard snow maybe that might have losen it
I also heard that it might be a rubber band on gear shifter / that might have broke or torn -
Old Mar 4, 2014 | 01:36 AM
Thermo's Avatar
Veteran: Navy
Juan, I would first start with checking the tranny fluid level. If the level gets too low, it will cause the tranny to sometimes shift into neutral in some cases. From there, see what you have.
Old Mar 4, 2014 | 07:56 PM
thanks bro going to get trains looked at tomorrow- but would like to check out the reverse cable myself can u give me a description- i went under it today couldnt find it -
Old Mar 5, 2014 | 03:27 AM
Thermo's Avatar
Veteran: Navy
Juan, if you have the drive gears, then your problem is not the "reverse cable" as the tranny only uses a single cable to shift through all gears.
Old Mar 6, 2014 | 08:03 AM
Yea I see so I believes my only option is switching out tranny -
I did saw a thread that a guy fixed this same issue on his own - he didn't need to pull tranny out all he did located the bolt that holds in place the pin to the reverse band - & drilled hole to adjust it from there - it worked for him
http://www.justanswer.com/jaguar/3f9...o-reverse.html
So I Got three option get it rebuilt or used one - or sell
Thermo you helped me out with a lot of situation what do u think is the best to go with for the long run cause I've heard looks of bad stuff happens with guys who switch out tranny or rebuilt them ?
Paora
Feb 4, 2021 12:36 AM
Msteiner
May 16, 2016 12:19 AM
LnrB
Oct 13, 2015 12:45 AM
NathanDD6
Oct 6, 2015 11:20 AM
millertic
Sep 30, 2015 08:11 PM
