X type wagon 2005 cooling fan keeps on running
Old Nov 17, 2018 | 09:01 AM
frujag's Avatar
Default X type wagon 2005 cooling fan keeps on running
Hello,
Have Jag x wagon 2005. Fan keeps running when I turn off motor. Why?
Anyone else with problem.
Can it be wiring or reistance induced problem
thanks
Old Nov 17, 2018 | 09:08 AM
NBCat's Avatar
Is the coolant level correct? Has any recent work been done that required draining and refilling the cooling system? If so, the system may have trapped air and must be bled correctly.
Most likely a failing or sticking thermostat. JLR part number is C2S11278.
Old Nov 20, 2018 | 03:40 PM
frujag's Avatar
thanks,
we will check coolant, thermostat and if this fails look at the relays.
any other sources or other models with similar problem?
Old Nov 20, 2018 | 05:41 PM
DUNKS's Avatar
Default FAN
HI. I had this problem and it turned out to be a faulty engine temp sensor.
Old Nov 21, 2018 | 12:44 PM
Dell Gailey's Avatar
1. Air trapped (needs to be burped)
2. Low coolant
3. Thermostat
4. Coolant system temperature sensor
5. Fan control module
KingHlayi
Dec 19, 2017 12:00 PM
GrahamPhotog
Nov 10, 2015 01:29 AM
bsprowls
Jan 20, 2012 09:26 PM
gerwitz
Jul 1, 2010 12:02 AM
goaliesdad
Jan 28, 2009 08:24 PM
