X-type wagon to pickup conversion.
Old Jun 21, 2015 | 10:17 AM
innzane's Avatar
Default X-type wagon to pickup conversion.
I am reaching here, sure not many have been inside them.
Question, when I cut the roof off an x-type wagon, is there
anything up in there that will cause real issues?
I would think nothing out of the norm, a few wires.
But in case someone knows.
Cut would be behind drivers area.
Like and x-type el camino
Old Jun 21, 2015 | 11:28 AM
Bud Tender's Avatar
The roof is part of the supporting structure on most cars.
Many years ago we cut the top off a Corvair. The frame sagged so bad the doors could not be opened. We didn't care, we just hopped over the doors into our new convertible.
Old Jun 22, 2015 | 06:21 PM
Dr dome's Avatar
My guess you would have to install a roll cage to the back corners or the drivers seat and run the bars to the back of the hatch area to hold the strength.
Old Jun 22, 2015 | 07:50 PM
Thermo's Avatar
Veteran: Navy
innzane, because of being a unibody design, doing what you are talking will result in body sag. You will need to build up the support on the underside of the car before cutting the roof. Most of your support is going to be needed under the front doors. You can stiffen up the rear by simply welding the rear doors shut and adding a little structural in the door seam on the inside. Probably will need a little bit of side to side build up too near the rear wheels to help the back from folding in on itself too. This is where a good cross member will come in to play.
Old Jun 24, 2015 | 03:00 PM
innzane's Avatar
Sounds like nothing is there then, good.
Bracing will certainly be used.
Thx for the input.
Old Jun 25, 2015 | 07:47 AM
euanT's Avatar
Yes there is!!! Wiring for the aerial, satnav, rear lights, amplifier for aerial etc!!!!
Old Jul 20, 2015 | 12:23 PM
mjtemple's Avatar
It's possible, I found these pictures on facebook
Old Jul 20, 2015 | 12:29 PM
Alfadude's Avatar
Is that an X-Camino or a Jagchero?
Old Jul 20, 2015 | 04:33 PM
Thermo's Avatar
Veteran: Navy
I didn't say that it wasn't possible. I am just saying that I hope you don't get into a wreck with the car. With the car being a uni-body design, it uses a lot of the body for its structural strength. If you are using a FWD only X-Type, then this isn't quite so much of a concern as the stresses in the car are less and you haven't modified the portions that would see the most stress. BUt, if you get hit in the side with the modified X-Type, I have a feeling a lot of things are going to come crushing in on themselves. Hopefully in the one that is pictured, they incorporated a good cross brace with rounded edges to help "throw" the stress around the passenger compartment. But, this is the engineer coming out in me.
Paora
Feb 4, 2021 12:36 AM
Msteiner
May 16, 2016 12:19 AM
Socal_transplant
Oct 1, 2015 01:15 AM
millertic
Sep 30, 2015 08:11 PM
