X_TYPE Handbrake problem
Old Jul 26, 2009 | 02:49 PM
Thermo's Avatar
Veteran: Navy
Kevin, I had a problem similiar to yours. What mine ended up being is the e-brake mechanism on one of the rear calipers was binding up. This causes the equalizing bar on the output of the handbrake to rotate and give you that "soft" feeling. You can isolate the problem by simply pulling on the e-brake to as far as it will go and then climbing under the car. The side with the equalizing bar closest to the rear tires is your bad side. If you pull off the tire, you can see the mechanism move a little bit and then it will stop. I tried freeing mine up by lubing and whatnot and nothing helped. So, you are looking at a new caliper.
Do a once over of the cables just to make sure that you don't have a cable that is binding up. This is easiest done by disconnecting the cable from the "bad" caliper and then resetting the e-brake. You should see the equalizing bar shift the opposite way.
Hope this helps. Just for reference, a new caliper costs around $110 plus any fluids that you might need.
Old Jul 26, 2009 | 04:32 PM
dennis black's Avatar
how low are your pads in the rear....what i did to solve this problem was put knew pads and what it did was put more meat so when you pull it up it did not have to go far ...that was my resolve ...your problem may be differant...now my handbrake grabs and releases
jdzubas
Oct 4, 2015 09:14 AM
Richard_gib
Sep 12, 2015 07:08 PM
Tar
Sep 6, 2015 11:24 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
