XE ( X760 ) 2015 -
Has anyone done Meridian retrofit
Old Dec 6, 2025 | 12:43 PM
Melo's Avatar
Default Has anyone done Meridian retrofit
Title is a bit click-bate. Car has donor parts and I'm not sure if configuration is solid anymore. I'm looking if anyone has knowledge which are right parameters in car configuration (CCF) so that Meridian works as factory planned. My car has Meridian from factory, but when reading CCF it's very difficult to understand if file is really supporting it as should. Values are misleading: Center speakers, subwoofer are flagged to be not in use, low line audio has configuration etc.
Secondly, I'd have troubles to understand how to use SDD in engineering mode so that I can change parameters. I can access engineering mode and see all three different component (BCM/xxx/CCF) and it there is a difference between them, but I can't get any optional values and alter existing ones. Can someone help me a bit and guide me, PM is fine as well?
All the best,
Mikko
Old Dec 8, 2025 | 05:01 AM
DJS's Avatar
DJS
I’d try the General Tech Help forum, there are a lot of SDD threads there. Note that PMing won’t be enabled for you ‘til you reach 5 or 10 posts.
https://www.jaguarforums.com/forum/general-tech-help-7/
Old Dec 10, 2025 | 02:04 PM
Melo's Avatar
Thanks DLS for this tip! I'll do proper new post during weekend with more detailed information. I did some analysis of my car's CCF and that seems odd to me, I'm increasingly sure that something has happen and audio settings are not quite right. Also I think that climate control configuration is missing heated seat option -> seat heating button is dead. Now I just need to get confirmation of right attributes regarding both of those.
KantawR
Jul 13, 2024 07:30 PM
NTL1991
Sep 17, 2021 04:22 AM
slash32487
Oct 14, 2020 05:18 PM
ddillenger
General Tech Help
Jul 23, 2019 06:27 PM
lunagry
Oct 6, 2014 11:18 PM
