XE ( X760 ) 2015 -
Help identifying this lever and cable under the hood.
Old Feb 3, 2026 | 03:34 PM
jtullos's Avatar
Default Help identifying this lever and cable under the hood.
Hi all,
2018 XE 2.0L diesel - what is the little lever and cable under the engine cover? It appears to run back towards thru firewall then disappears where I can't see it anymore. The lever is broken and the cable is pulled thru a couple of inches. What does this little guy pull?
Thanks! Jimmy
Old Feb 3, 2026 | 04:04 PM
that is to disengage the transmission on a total loss of power and you need to put the car in neutral to move it
Old Feb 3, 2026 | 04:09 PM
jtullos's Avatar
Thank you! Do you have a parts diagram reference for the part or what the part is called per Jaguar?
Old Feb 3, 2026 | 04:17 PM
The following link to SNG Barratt's will help you - looks like you have to purchase the whole assembly - lever/cable etc.
https://www.sngbarratt.com/English(U...assembly/35351
Old Feb 8, 2026 | 08:37 AM
clubairth1's Avatar
Community Influencer
Be aware that you need a tool to operate that lever. It should be somewhere around your spare tire area. It clips onto that cable and has a lever to squeeze that will put the transmission into neutral. Be SURE you have this tool in your trunk!
While your version may look different all JLR AWD cars REQUIRE this tool.
Be sure to read the owners manual on how to reset this and put the transmission back into normal mode afterwards.
With the cable pulled out that far is the car in N or can you still drive it?
Old Feb 10, 2026 | 10:08 AM
Floy3509's Avatar
Originally Posted by jtullos
Hi all,
Thanks! Jimmy
that's to put your car in neutral if the power goes out
Old Feb 11, 2026 | 08:03 AM
clubairth1's Avatar
Yes that's exactly what I said above?
Deepstuff
Oct 20, 2025 06:50 PM
primaz
Jun 12, 2025 05:26 PM
Greg in France
Jun 11, 2025 07:20 AM
brinny
Mar 12, 2025 12:37 PM
kbeachy
Sep 2, 2019 04:32 PM
