XE ( X760 ) 2015 -
Remove rear door trim.
Old Sep 12, 2020 | 09:06 AM
retsel's Avatar
Default Remove rear door trim.
Hello, can someone tell me how to remove rear door panel?
Thank you.
Old Sep 14, 2020 | 06:57 AM
Rummy636's Avatar
REMOVAL
CAUTION:Use a suitable trim tool.
NOTES:
  • This procedure contains some variation in the illustration depending on the vehicle specification, but essential information is always correct.
  • This procedure contains illustrations showing certain components removed to provide extra clarity.
  1. Remove the rear door interior handle trim.
  2. Remove the bolt.
    • Remove the access cap.
    • Remove the bolt.
    • Remove the rear door stowage compartment trim.
  3. Remove the 2 center bolts.
    • Remove the rear door window switch.
    • Disconnect the electrical connector.
    • Release the 9 plastic clips.
    • Release the 5 clips at the top of the door trim panel.
    • Release the door trim panel inner handle cable.
    • Remove the rear door trim panel.
    • Remove and discard the 9 plastic clips.
Old Sep 14, 2020 | 07:13 AM
retsel's Avatar
@Rummy636, many thanks.
Old Sep 14, 2020 | 03:44 PM
retsel's Avatar
On the front doors installed.
PeteK812
Feb 26, 2020 04:07 AM
Mark in Maine
Sep 13, 2019 04:32 PM
JTsmks
Nov 21, 2015 11:57 AM
Belfast Boy
Jun 17, 2013 03:43 PM
