XE ( X760 ) 2015 -
SOS Limited Telematics Battery Replacement
Old Sep 3, 2023 | 12:19 PM
CASonCALL's Avatar
Default SOS Limited Telematics Battery Replacement
Not sure if this is the proper place to put this. Have had the dreaded SOS Limited error message (Done on a 2017 XE R-Sport 35t but should work with any telematics unit as they are pretty much the same across many Jaguar and Land Rover Models). After Researching a bit I came to the conclusion that it was an issue with the Telematics Module back up battery voltage not being up to required capacity anymore. As there wasn't a real guide that I saw from searching available to solve this issue and reset the module without a computer I figured I would make one real quick.
Disclaimer: Note that this worked in my situation and may not necessarily work for every model year of the car, I take no responsibility for the actions of any mechanic, shop, or fellow garage mechanic. This is a one beer/energy drink Job.
I sourced my Telematics Battery from Rovers Land (aka LRBRITISHPARTS) in Miami, they were the only ones that had the T4N2591/LR046049 (?) part needed. Everyone else had cheap and crap Chinese knock-off parts.
1. Pull off the Door seam seal from vehicle body on the Rear Passenger Side, this partially holds in the Bolster Trim for the rear seat. I also dropped the seat through the trunk when doing this.
2. Pull Bolster trim away from the body exposing the Telematics Module. I used an empty water bottle and wedged it between the bolster and the body to keep the bolster propped.
Above is what the unit looks like once you pull back the trim. The general configuration of the battery in the module is displayed above.
3. Use a 2mm Allen wrench to remove the cover screw. Once removed you will need to pull off the door that has two hooks on the bottom so pull the door away from the module before pulling it up.
4. Pull battery down over the connector and remove the connector from the telematics unit by pressing on the top of the wire harness tab and gently pull on the connector. It is pictured below with an arrow on the tab. Once removed you will need to put the battery back on in reverse order (reconnect the harness with the tab facing up into the connector, gently fold over battery into battery slot).
5. Angle cover back onto telematics unit, apply gentle pressure to keep the cover down and the battery seated while you put the screw back on the top end of the cover. Tighten till the screw is seated.
6. Remove wedged item from bolster and seated back in place. While holding it down, place the partially removed seam seal back into place.
The SOS Limited will not automatically go away as the vehicle does not automatically register the replaced battery. You will have to open the cover to the maintenance assistance button located on the driver side of the SOS button panel. I pressed on the top of the button cover to drop it and expose the button for maintenance assistance.
Turn on vehicle accessories by pressing the start button WITHOUT pressing the brake peddle.
Press and Hold the maintenance assistance button. It will begin blinking somewhat rapidly in an amber light. Hold button until it starts to blink slowly. release the button and turn accessories/car off. Wait 5-10 minutes for the Telematics System to run a self diagnostics and register the new battery and voltage level.
The SOS Limited error was cleared on the XE after performing these steps. Photos added and captions added as needed. Let me know if there is any further clarification needed. Cheers
Old Sep 3, 2023 | 02:30 PM
DJS's Avatar
DJS
Nice write-up. Thanks for that!
Old Sep 3, 2023 | 05:06 PM
dangoesfast's Avatar
Great write-up
Old Dec 12, 2024 | 02:05 AM
Jnrfvor's Avatar
If you're dealing with "SOS Limited Telematics Battery Replacement," it's essential to understand how the telematics system functions and integrates with your transportation needs. This system plays a vital role in monitoring vehicle performance, tracking, and communication. Here's a helpful resource to dive deeper into the concept: telematics system.
Old Sep 21, 2025 | 02:56 AM
greenjaaaaaaag's Avatar
Default SOS Not Available
Has anyone seen whether or not this will also fix an “SOS not available” message? I started getting that recently and have not seen anything across all of the forums on how to fix this. Basically a couple of weeks ago, I started getting this message and then the car would not start at all. It would turn on but as soon as you put your foot on the brake and pressed the ignition, the cluster gauge would do its normal start up with the lights and needles moving but the car would not crank and as soon as the needles moved back to 0 the car would shut off entirely. I tried replacing the main car battery, which fixed the issue for a couple of weeks but the message just came back and I have no idea if the whole TCM is bad or if it’s just the batteries.
defalco733
Jun 14, 2024 07:05 PM
Tubsie
Feb 15, 2023 12:46 AM
Britrover
Sep 3, 2019 12:35 PM
ChilledJames
Oct 17, 2014 06:38 PM
Paul Pavlik
Sep 23, 2011 01:47 AM
