XE ( X760 ) 2015 -
Unable to maintain Bluetooth streaming (iPhone)
Old Mar 11, 2017 | 06:05 PM
drtdvl's Avatar
Default Unable to maintain Bluetooth streaming (iPhone)
When I am wearing my Apple Watch (Series 2) and streaming music through Bluetooth, the music will play for a short period of time (less than 1 song and up to 3 songs) and then kicks me back to the radio. If I put my watch on airplane mode, there is no issue.
I currently have an iphone 6S running iOS 10.2.1. The car's infotainment system is the Pro Version. I recently did the software upgrade for the car about two weeks ago.
Is anyone else running into this problem? Would this be an iOS problem or a software issue with the infotainment system.
Thank-you.
Old Mar 11, 2017 | 07:13 PM
ololly's Avatar
You are definitely not alone. Check out this discussion:
https://discussions.apple.com/thread/6866663?tstart=0
I think that's the Apple watch/iPhone connection to blame. I have an iPhone 6 and a smartwatch - Pebble - and it connects to my IC flawlessly and stays connected.
As a workaround you may do this:
Forget both Jaguar and Watch BT connections. While sitting in your Jag pair it to IC (or ICP) first, and then pair it to your watch.
If this doesn't work try to leave your Watch on WiFi only and disable the bluetooth on it. Then it will communicate with your phone via WiFi and the phone will use BT to connect to IC. The watch will discharge faster though...
Old Mar 12, 2017 | 01:39 PM
Qlogic's Avatar
I have the same problem. It stays connected for a minute then disconnects. It is very annoying. I have a one plus 3 Android phone
Old Mar 12, 2017 | 02:01 PM
drtdvl's Avatar
What I have ended up doing to stream music is to put my Apple Watch in Airplane Mode.
Old Mar 12, 2017 | 02:03 PM
ololly's Avatar
I take it that none of my suggestions worked, right?
Old Mar 12, 2017 | 06:56 PM
drtdvl's Avatar
I tried it out and thought it was working but after a few songs, it kicked me back to the radio.
Old Mar 12, 2017 | 06:57 PM
drtdvl's Avatar
I also tried removing my phone from IC, deleting the Jaguar Bluetooth profile from my phone and then resetting my network settings on the phone.
I reconnected everything and still the same problem.
Old Mar 12, 2017 | 08:22 PM
Qlogic's Avatar
No go for me either. I did notice it doesn't drop as often if it's been connected for about 5 min before I start playing. Also depends on where I put the phone in the car. It is really weird
