XF (X260) 2015 onwards
09 XF 4.2 Luxury overheating.
Old Nov 23, 2019 | 03:29 PM
Christopher Loomis's Avatar
Default 09 XF 4.2 Luxury overheating.
My baby is continuing to over heat, I've replaced the thermostat housing thinking that was the issue(it was damaged) but its still overheating. Any suggestions on how to fix that? I appreciate your help.
Old Nov 23, 2019 | 03:33 PM
Fraser Mitchell's Avatar
What engine ? The water pump may not be pumping if some vanes have broken off and fallen inside the coolant jacket. Are you getting heat as usual into the cabin ? Only other thing is a clagged up radiator, either inside the tubes, or leaves and crud off the road blocking the air from passing through.
Old Nov 23, 2019 | 03:35 PM
Its a 4.2L not supercharged. I am not getting heat into the cabin.
Old Nov 24, 2019 | 04:55 AM
No heating, eh ? It does sound as if you need to investigate the water pump. However I'm not sure if these cars have an auxiliary coolant pump (electrically powered). So check pump and possible electric pump.
Old Nov 24, 2019 | 05:11 AM
i appreciate any help I can get. Thank you.
Old Nov 25, 2019 | 01:27 PM
CarsonCitySmith's Avatar
When you replaced the thermostat did you notice calcium or other crud deposited on the inside? That might indicate the condition of your radiator.
Also, there is another forum for the earlier XF models, you might inquire there.
P.
Old Nov 26, 2019 | 02:38 PM
Update*** Took the water pump off and this piece of the thermostat housing was stuck in the fan. Didnt take long to get the pump out. I appreciate all your help. So much!!!
Old Nov 29, 2019 | 01:20 PM
Default Still overheating
I've changed the thermostat, and housing, plus the water pump and its still overheating. There's nothing indicating its the heads and the radiator is working. Is there something else I'm not doing right?
Old Nov 30, 2019 | 12:50 PM
hiltoncam's Avatar
Doesn't this belong in the X250 section?
jaguarxfv8
Nov 12, 2018 08:32 AM
leadfoot4
Nov 8, 2017 04:47 AM
Robert442
Aug 10, 2015 09:59 AM
dennisw
Mar 16, 2012 10:38 AM
