XF (X260) 2015 onwards
2013 XF 3.0 plastic tubes from water pump
Old Feb 18, 2018 | 05:04 PM
CzechFrank's Avatar
Default 2013 XF 3.0 plastic tubes from water pump
Hi Everyone.
I have a 2013 XF 3.0 AWD with 70,000 miles on it. There is a slight coolant leak, and my mechanic says it is the plastic tubes that run from the water pump and under the supercharger. Apparently this is a know issue for the car and the tubes are on back order and about $130 but the installation is the expensive part because the supercharger will have to be removed to get to the job site.
My questions are:
1. Is this indeed a know issue and does it all makes sense the way it is described to me?
2. If so, is there a better part than the "know issue" OEM which common sense says I'll be in the same place in another 70,000 odd miles?
If you have suggestions here, links would also be much appreciated.
Thank you
Old Feb 18, 2018 | 05:32 PM
mleskovar's Avatar
Try the X250 forum for a better chance of an answer. I'm assuming it's a gas engine? I hope they solved this issue with the X260.
Old Mar 26, 2018 | 10:08 PM
Barron Voorhies's Avatar
Default A/C problems
I have a 2013 XF and today I turned my A/C on and about 2 minutes later a Battery not charging sign came on. The A/C is not blowing cold either.
Old Mar 27, 2018 | 10:35 AM
mleskovar's Avatar
Sounds like a belt is broken......
Polyesterpig
Nov 18, 2015 07:20 PM
larys192
Dec 21, 2014 04:35 AM
AntixSD
Apr 3, 2010 07:40 AM
Tomlite
Apr 25, 2009 02:18 PM
