2015 XF Engines System Fault (United States)
Hello! Today my wife’s 2015 Jaguar XF 3.0 Supercharged (gasoline) had an Engines Sytem Fault come up. She was unable to turn off the car.
I was able to turn the car off by unplugging fuse F37. I’ve since done the following:
unplugged the negative terminal of her battery. Some slight corrosion but nothing alarming.
let sit for 20 minutes and reconnected the battery.
I also checked other fuses and only saw one fuse blown that I replaced (F37 not sure what that one is).
the car now receives power but the jaguar logo stays on the screen and nothing in the gauge cluster lights up. She does have a code I was able to pull prior to shutting off the car for on P0087 I believe.
the car now will not turn on at all. What should I be checking? The fact that the car will not even attempt to start makes me think it’s not getting enough power to try. But the gauge cluster won’t even power up when I press the start button without the brake pedal.
any help would be greatly appreciated!!!!!
ToadMaster
May 21, 2024 08:49 AM
Danah J
Oct 22, 2022 12:54 PM
