XF (X260) 2015 onwards
Battery not charging message
Old Jun 15, 2021 | 02:02 PM
tiberius 33's Avatar
Default Battery not charging message
Hey . If can somebody help me ..,
i have an xf 2.2 diesel 190cp 2013 ,whit the message “battery not charging “ . I have checked the battery , i looks like everything is ok , alternator also . I changed also the minus cable , and i’ve run also a Jaguar Tester to a local dealer . Everything is normal . But i still have the message on bord .. can anybody help me ?
Old Jun 15, 2021 | 09:41 PM
2018XF25T's Avatar
Sounds like an alternator problem, isn't giving enough charge to the battery. How did you test the alternator? It could be the battery too. I'm not familiar with diesel engines..is there a slippage on serpentine belt, if old, change it. If you are in the USA, go to AutoZone, O'Riellys, NAPA, AAP or any auto parts that sells batteries and they'll check the alternator & battery for you FREE OF CHARGE.
allsortsmg
Sep 2, 2023 06:34 AM
sulthan_amk
Dec 12, 2022 10:09 PM
LoveHerTopless
Feb 8, 2018 11:47 PM
joey4420
Nov 8, 2014 08:41 AM
EngineerReeves
Nov 10, 2013 01:34 AM
