XF (X260) 2015 onwards
Front License Plate Mount
Old Aug 27, 2016 | 01:34 PM
Jay_Davis's Avatar
Default Front License Plate Mount
It looks like you have to drill into the car to install the front license plate. I hate doing that. Has anyone found an alternative front plate bracket?
Old Aug 27, 2016 | 09:15 PM
Porscheluxe's Avatar
My dealer installed a plastic frame with a contoured mount behind it. It is inoffensive, at least as a required front license plate can be.
From past research, I've seen various brackets that attach to a threaded tow hook mount. In the case of the XF, the angle and location would be far uglier than the stock mount IMHO.
I also recall seeing assemblies that attach beneath the front "bumper", and while searching for an example I ran across License Plate Central at License Plate Accessories Looks like most available solutions are shown on that site. I also ran across retractable plate mounts with wireless remotes, apparently for show cars. Surprising how many traps there are for this particular mouse.
Old Aug 28, 2016 | 11:17 AM
Magnumforc's Avatar
I checked on the license plate brackets that fit under the valance and hold the plate away from the front of the vehicle. But, I also found they reduce the clearance between the valance and the ground so bumper blocks in parking lots end up becoming a big enemy (worse than usual) and the valance will ride up and over the block and may become stuck. Ouch!
I bit the bullet and had the dealer install the plate. The find for not having one far exceeds the cosmetic value of not, at least IMHO.
Old Aug 5, 2019 | 10:41 PM
JagWire_5280's Avatar
Bringing back this Thread, I just got my plates today, I went with a SlyBracket, fits perfect, my only concern is that pretty much completely covers up the vent on this side, are the front lower corner vents to get air to the rotors and does it look like enough air can still get through ? The kit comes with extra spacers so I could mount it in to the lower middle vent, I just really like the look of it on the side.
Sly Brackets / BozzMount
Old Aug 6, 2019 | 11:03 AM
mleskovar's Avatar
Originally Posted by Magnumforc
...The find for not having one far exceeds the cosmetic value of not, at least IMHO.....
Say what? It's usually just a fix it ticket (no fine) in California if they even bother writing you up for it. I've been told by several police officers that the "no front plate" is overlooked because it gives them an ideal situation to pull someone over if they're just suspicious. For a while they were ticketing people for no front plate in my neck of the woods because red light cameras were being installed in a lot of locations. Then something happened ..... I think they were successfully challenged in court .... and the cameras came down.
XKR2000
Dec 8, 2016 07:20 AM
Beav
May 18, 2016 01:10 PM
Bhpbug
May 3, 2016 12:26 PM
Kief
Apr 26, 2016 10:29 AM
Feb 7, 2007 07:21 AM
