XF (X260) 2015 onwards
Garage Rmote Control
Old Feb 20, 2024 | 05:51 PM
Carson City Smith's Avatar
Default Garage Rmote Control
I am having intermittent troubles with my garage remote control. The buttons on the rear view mirror. It worked fine for several years but recently has been spotty. Sometimes I need 4-5-6- presses to get it to work, other times the door responds on the first click.
I also have some suspicions about the garage door opener, that may be the problem, but I wanted to check first with the hive mind here, has anyone had any trouble with the Jaguar remotes?
4th year driving the thing, no problems, except the dealer keeps over filling the oil every year when I get it changed.
We had a good long trip over the Rockies into eastern Colorado this summer and back. Hot summer at home made the Jag AC pretty comfortable.
P.
Old Feb 24, 2024 | 06:50 PM
rbr's Avatar
rbr
Mine fails to connect intermittently, no definite idea as to cause but I find that with the built in unit I must get much closer to the receiver (and my garage door) than with the previous hand held transmitters. I still keep an old handheld in the car for when the mirror doesn't work. I postulate that perhaps for some regulatory reason the signal is somewhat less powerful? FWIW my door openers are 30 yr old fixed code units.
Old Feb 27, 2024 | 01:26 PM
Right. My opener is maybe 20 years old. The hard wired accuator stopped working a couple years ago, a replacement made no difference, the wiring it good, it is an internal problem but the original remote works fine. And the Jaguar mirror remote works fine sometimes, sometimes only after 4-5-6- presses. So on a balance of unknowns, the idiopathic data, I fault the Jaguar mirror remote for the intermittent failure.
Thank you for your response.
The more longer drives we take the less concern for the garage door opener. Maybe that is the lesson learned here.
P. Smith
Carson City, NV
2016 XF
Old Feb 29, 2024 | 10:49 AM
mleskovar's Avatar
I had the same problem and it turned out to be the garage door opener. Also once I changed the position of some wiring in the garage and it became intermittent again. I changed the position of those wires and the problem stopped. Sometimes my wife's car (BMW) fails ..... she moves the car just a couple feet and it works.
datriani
Jul 28, 2021 10:42 PM
jerome41441
Sep 2, 2020 03:11 PM
lrbrowns
Sep 11, 2019 08:59 PM
ronald4313jm
Sep 26, 2015 07:57 PM
Jayt2
Feb 8, 2011 03:47 AM
