XF (X260) 2015 onwards
I need a nuclear option
Old Jul 26, 2023 | 11:58 AM
Jagrbomb71's Avatar
Default I need a nuclear option
Where is the audible warning speaker on a 2015 XF Sport? It's behind the instrument cluster somewhere but I don't know specifically where. Dealer isn't giving me anything. I have a EPB beeping that will not stop. I have been told that the entire..... ENTIRE gear selector unit in the center console will need to be replaced. Here's the good news.... Jaguar can't even make them because of supply chain issues. All the used ones on eBay are either trash or the wrong part number.
I just want this beeping to stop. I know I can't cut the wire but I can deaden the sound or disable the speaker in some way until I can replace this unobtainable part
Old Aug 13, 2023 | 12:44 PM
odurandina's Avatar
I had to replace a gear selector. The correct used part was sourced.
If i remember correctly, my tech discovered it had to have a unique code on it---
re; via a new gear selector (only), adding something like ~$800 to the cost.
Ransom paid, w/ another notch added to my incredulous tab.
Old Aug 13, 2023 | 01:00 PM
Jagrbomb71's Avatar
I feel you. I did however, engineer a band-aid while on the search for a suitable replacement gear selector assembly. Took out the instrument cluster and filled the speaker in question with as much cotton ***** it would take. Now, I can barley hear it and it's drivable for the foreseeable future. Not an elegant fix but for 2 hrs work, it's not bad.
Jagrbomb71
XF (X260)
Jul 23, 2023 06:15 PM
Pistnbroke
Mar 13, 2023 05:00 AM
raa
Mar 13, 2018 02:07 PM
Shislop
Dec 4, 2017 01:50 PM
Skarre
Apr 17, 2016 02:55 PM
