XF (X260) 2015 onwards
IPod source option no longer shows up when iPhone connected via USB
Old Aug 1, 2021 | 06:09 PM
azeemj's Avatar
Default IPod source option no longer shows up when iPhone connected via USB
Hi all
firstly my apologies if this has been answered on the forum. I did a search but found nothing.
Recently got a an XF R Sports 2017. Using an iPhone and connectivity via Bluetooth is fine. However when connected via usb cable I was able to use the Jaguar App. Also sound quality is a lot better with the cable when selecting the iPod option from the media source list.
All of a sudden iPod option does not display. Nor does it detect the Jaguar App.
Bluetooth still works fine.
Have changed cables (using orig Apple cables) and used different iPhone but still nothing.
No software updates were done on
iPhones.
Was thinking to reset media system? Not sure how.
Any thoughts on what has gone on and how
I solve this.
thank you
Az
Old Aug 2, 2021 | 03:33 PM
2018XF25T's Avatar
Maybe it's your iPhone? Have you tried cleaning the connections?
https://www.jaguarannapolis.com/jaguar-apple-carplay/
Old Aug 2, 2021 | 04:12 PM
azeemj's Avatar
I haven’t no. As I mentioned I have tried to use another cable and another iPhone.
but something weird happened today. I disconnect the phone from BT (bluetooth) and when I reconnect BT and connect the cable the iPod source option appears and then miraculously disappears taking away the BT source option too.
I am able to listen to music using BT on its own.
Anyone else experienced similar issues?
I will try the deep clean option too. Worth a go nothing else is working so far and it’s becoming frustrating.
Old Aug 3, 2021 | 06:18 PM
azeemj's Avatar
Default Solved
well would you believe it. I cleaned out the iphone as it had fluff in there. Works now. So shocked that it was still able to charge but nothing connect to the Jag.
many thanks for the suggestion.
WinterJag
32
Aug 6, 2025 05:54 PM
sjhesketh
May 5, 2021 07:36 PM
Andy6878
Jan 30, 2021 02:25 AM
vacolorito
Jul 10, 2019 06:33 PM
tho
Mar 18, 2012 08:04 PM
