XF (X260) 2015 onwards
Jaguar XF X260 - One side DRL not working
Old Mar 12, 2024 | 07:04 AM
Parth's Avatar
Default Jaguar XF X260 - One side DRL not working
Hello everyone, Need guidance from you all.
I own a Jaguar XF X260 Diesel in the UK. Lately, I've noticed that my left side daytime running light (DRL) isn't working when I shift the car from Park (P) to Drive (D). Oddly enough, when I unlock the car, both DRLs work fine, but once I shift the gearbox to Drive, one of the left side DRLs goes off. Any ideas why this might be happening?
Old Mar 13, 2024 | 09:52 AM
Parth's Avatar
Default No Reply
Hi all, please someone who knows the issue can assist me ?
or
if someone knows where is Body control module/Control junction box located on X260 UK spec? I tried locating at drivers footwell however there is nothing there.
any help would be appreciated. Thanks.
Old Mar 13, 2024 | 11:12 AM
Welcome to the forums Parth,
The X260 Workshop Manual indicates the BCM/GWM assembly is in the LH footwell (see item 7):
This fault is extremely unlikely to be caused by anything as simple as a loose connection. The only systematic way to troubleshoot the issue is by scanning for relevant DTC's (Diagnostic Trouble Codes). You don't mention the year of your vehicle so I can't tell if this would require the old SDD (Symptom Driven Diagnostics) or the current JLR Pathfinder diasgnostics.
As you have bypassed the usual courtesy of posting an Intro, please read the guidance for new members ( https://www.jaguarforums.com/forum/n...ned-up-241802/ ) which answers many of the most frequent questions about getting started on the forum.
Old Mar 13, 2024 | 12:23 PM
Parth's Avatar
Default Year of make 2016
Thank you GGG. Apologies for bypassing the intro, I have now rectified it by introducing myself and update my profile by inserting year of make.
btw I tried checking today with OBD 2 Scanner, but it did not have me any error codes there.
Old Mar 13, 2024 | 02:11 PM
The BCM/GWM stores fault codes which can be retrieved using JLR diagnostics. A generic scantool will read the standard powertrain (Pxxxx) codes but these BCM/GWM manufacturer defined codes require dealer level diagnostics.
Left and right lighting circuits are separately protected. Power feed to the BCM/GWM left and right lighting circuits respectively are each protected by a 60 Amp fusible links in the BJB. All exterior lighting circuits are protected by Field Effect Transistors (FETs), located in the BCM/GWM, which can detect overloads and short circuits. On a normal circuit this would cause the fuse to blow but the FETs respond to the heat increase by disconnecting the supply to the affected circuit. When the fault is rectified or the FET has cooled, the FET will reset and operate the circuit normally. If the fault persists the FET will cycle, disconnecting and reconnecting the power supply.
If ther was a fuse blown by the DRL fault, it would be a lot easier to trace as the evidence would be there permanently but because the FETs reset it's almost impossible without compatible diagnostics.
Old Mar 14, 2024 | 04:48 AM
Parth's Avatar
Ok. Thank you.
I assumed I should be able to self-serve myself but looks more complicated than that.
I will book in for a check with dealer next week.
thanks again. 👍🏻
Old Mar 14, 2024 | 06:02 AM
You could be into three figures just for a diagnostics session and they'd just love to sell you a new BCM for around 500 UKP. Make sure the Service Manager understands it's your rules and not his.
Old Mar 14, 2024 | 06:15 AM
Parth's Avatar
Oh my…..
thanks for the heads up about that.
1. Is there a possibility that this issue can be resolved without changing the BCM, or is that the only solution as suggested by the dealer (if that's indeed their recommendation)?
2. do you recommend any good dealers near london area ?
I was thinking to go “Harrow Service Centre” as they are near my area and they seem to be qualified independent.
thanks
KKostas
Jan 25, 2023 06:18 AM
Nick Cowger
Apr 24, 2019 09:16 PM
