XF (X260) 2015 onwards
Led pace headlights
Old Mar 28, 2019 | 11:31 PM
Ian Campbell's Avatar
Default Led pace headlights
Hopefully I’ve put this post in the right section. My xf has xenons but the iindicator is a standard bulb so I was thinking of swapping them too led technology pace ones. Are they a straight swap or or a huge deal ? Thanks all 2016 xfs 3.0d
Old Mar 29, 2019 | 05:16 AM
Ian,
YES - you have posted in the relevant forum for technical questions about your 2016 XFS.
Old Mar 29, 2019 | 11:23 AM
Brutal's Avatar
If you have the bulb number then look them up on amazon or ebay to corresponding led replacement. Remember to get a clear for clear or amber, red etc. Even if they are clear i would recommend a superbright led of the same color as any lensed light you replace. When i have done red side markers they looked pink, so switched to red led and very happy.
Old Mar 29, 2019 | 01:19 PM
Sorry I wasn’t clear I want to change the entire headlamp units for the LED technology ones as against my hid units I have now.
Old Mar 30, 2019 | 01:17 PM
Thought this would be a popular modification if its doable ? Anyone out there know anything about swapping these please ?
Old Apr 1, 2019 | 03:33 PM
Googsy's Avatar
Hi yes this can be done. I have just bought a set to replace my Xenons. You will need to drop the bumper in order to remove existing headlamps the new ones just fit straight in. Everything will work with the exception that on the inside of the car the indicators will blink faster than normal as the system will think a bulb has been blown. This can be remedied by fitting a resistor each side in parallel . I haven't done mine yet as I done know which of the wires is the indicator and would like to know in advance. I have a circuit tester which I hope will help.
Another forum member has successfully done this Ian Kerry who kindly helped me link here to post
https://www.jaguarforums.com/forum/x...lights-208064/
Hopefully thats useful.
Conor
ian_kerry
XF (X260)
21
Jun 17, 2023 01:32 PM
jagxkrtoofast
Aug 30, 2018 02:14 PM
John Jones
May 21, 2018 05:51 AM
bk000
F-Pace (X761) / C-X17
Feb 10, 2017 06:13 AM
tomas6791
May 2, 2016 12:11 PM
