XF (X260) 2015 onwards
LKA and Lazy Entry Activation
Old Jun 12, 2025 | 02:33 PM
gbkwiatt's Avatar
Question LKA and Lazy Entry Activation
Does anyone can put some light on what do I need to activate LKA ?
I currently have TSR,AHBA,LDW - but not sure how to check if I have needed hardware for LKA. Also if anyone has the lines to activate in SDD
I was also trying to activate Lazy Entry - which supposed to let you save memory seat position to a key fob, and adjust it as you enter based on the key you hold, but after finding that option and changing to `Active` nothing really happened.
Old Jun 12, 2025 | 04:13 PM
gbkwiatt's Avatar
I can't see edit button (?)
Edit:
I've only was able to enable easy entry which moves steering wheel up when opening the drivers door. There are 3 options in CCF "Lazy Entry", "Easy Entry", "Easy Entry Menu".
Enabled all that but no option or menu in convenience options on cluster.
I suspect maybe something like "Re Learn Configuration" on Cluster is needed, just like I needed to do for InTouch module to enable "PDC auto activation" menu option. But I don't feel comfortable to mess with a cluster yet, until someone will tell me it is safe to do
Grant Eisworth
Nov 10, 2023 04:13 AM
gmcgann
Jul 15, 2020 12:55 PM
Paulie710
Mar 20, 2019 08:02 PM
L80ous
Sep 17, 2016 07:01 PM
Grant Francis
Apr 3, 2013 05:52 AM
