XJ ( X351 ) 2009 - 2019
Convenience Mode (seat to key programming)
Old Sep 14, 2016 | 02:57 PM
L80ous's Avatar
Default Convenience Mode (seat to key programming)
Does any-one know how to do this with the keyless entry fob. Got 2 keys and can't for the life of me figure out how to do it, it isn't like the old Jag's cause you can't put a key in and turn to postion I. Want the seat to move to position 1 when using one key and position 2 when using the other....help!
Old Sep 14, 2016 | 04:33 PM
XJsss's Avatar
To the best of my knowledge and 4 years of ownership the X351 does not associate "memory" to a particular key fob.
Old Sep 14, 2016 | 06:12 PM
carzaddict's Avatar
i cant remember, but i believe you have to press and hold the unlock button on the key while simultaneously pressing the memory preset number you want to pair it to
it should explain it in the manual
Old Sep 15, 2016 | 05:02 AM
L80ous's Avatar
Tells you how good it is in the manual but doesn't say how you program it, also tired that, but without the car running will see if it makes any difference then.
Old Sep 17, 2016 | 01:01 PM
L80ous's Avatar
So no actually uses this option then? I'm guessing it doesn't have it?
Old Sep 17, 2016 | 01:25 PM
Thermo's Avatar
Veteran: Navy
Looking in the service manual for a 2010 XJ, there is no mention of the keyfob being used for adjusting the seats based on which keyfob is near the car. So, it would appear that the car does not have a recognition of the keyfob to a set of seat positions.
Old Sep 17, 2016 | 07:01 PM
dga57's Avatar
If it is equipped with key fob recognition, then the fobs should be numbered 1 and 2. Mine is not, but it's five years old so can't speak to newer models.
Dwayne
Typo_Caps_Bot
Mar 16, 2018 04:41 PM
Adam Lueb
Oct 24, 2016 02:59 PM
95 Cat
Sep 9, 2016 08:53 AM
carzaddict
Sep 6, 2016 07:53 PM
carzaddict
Aug 24, 2016 03:35 PM
