XF (X260) 2015 onwards
Shifter knob stuck
Old Jun 20, 2022 | 06:54 PM
Bluizntx's Avatar
Unhappy Shifter knob stuck
Hello, I'm new to the forum. I am having a problem with my 2910 Jaguar XF Premium, the shifter knob is stuck and won't rise up. It was doing fine with no problems and then the next morning when I started the car the knob wouldnt raise up for me to put it in gear. Has anyone else had this problem and if so anyone have any sugguestions? I read something that said to see if the knob would go in gear even though it wouldnt raise up and it won't. Help please. I'm right in the middle of a big move this couldn't have happened at a worse time. Thank you for any help you can give me it's greatly appreciated.
Old Jun 20, 2022 | 09:43 PM
2018XF25T's Avatar
You can still switch gears even though the gear shift will not rise up. Just press down with your thumb & the index finger on top of the gear shift to get around it.
Your 2910 (I would assume that's a 2019) XF, is still under warranty. "IF" the mileage on the car is less than 60K miles (good for Jaguar USA only)
abonano
Oct 29, 2024 06:38 AM
3timejag
Jul 14, 2017 09:31 AM
BlacXJRcat
Oct 22, 2016 08:59 AM
mvivio
Apr 30, 2016 08:25 AM
