XF (X260) 2015 onwards
Sunroof question
Old Sep 22, 2016 | 06:19 PM
yntski's Avatar
Default Sunroof question
While using the sunroof there is two-stage opening. When I first had the car I thought that the first stage opened or rather just lifted the glass enough so that you can see about an inch of opening. Now I noticed that I can barely tell that it is lifted. I don't know if something happened to the mechanism that opens (lifts) the sunroof as I have had a lot of repair work done on it for another issue.
Short push of button just lifts the glass very little and a longer push of the button completely opens the sunroof.
My sunroof opens correctly but the first stage (lifting the glass) is where I question if it working properly.
Old Sep 23, 2016 | 05:40 PM
xfgirl's Avatar
Mine does the same thing so it's probably working correctly. I was also quite shocked at how little the sunroof lifts on the first stage.
Old Sep 26, 2016 | 11:28 AM
yntski's Avatar
It's kinda like why bother?
Old Oct 10, 2016 | 03:36 PM
BCJAG's Avatar
I wondered the same thing. It wont let much air in. I did check the mechanisms and they seem fine. The wind deflector 'volleyball net' is odd but it must work. Many car makers are using the sunroof sliding over the outside and not under the inside because it doesn't reduce interior head room on these more sleek vehicles. The F-Pace new Jaguar uses the outside (big) sliding roof. Our MB 230 sports coupe had the same system which worked fine.
AL
Old Oct 10, 2016 | 09:33 PM
mleskovar's Avatar
It's not intended to let air in but to let air out. It's an FCF.
XK_SL
Jan 31, 2024 07:55 PM
jagtoes
Feb 2, 2021 04:33 PM
vsol
Nov 29, 2016 08:48 AM
Anthony8858
Sep 10, 2016 04:53 AM
no401k
Sep 9, 2016 10:27 AM
