XF (X260) 2015 onwards
Windshield wiper questions
Old Dec 1, 2018 | 04:55 PM
rpd444's Avatar
Default Windshield wiper questions
Gents: I’m trying to replace my wiper blades on my ‘16 XF. There isn’t a ton of information on the internet about replacing the blades though I’m managing to figure it out. Anyway, I looked up the XF’s wiper specs on Rain X and Bosch and it said 22” for the driver’s side and 19” for the passenger side. But when I compare the factory blades to the one recommended, it’s a fair bit larger.
Anyone know why that might be?
The other question is how you get the I&L connector to work. I think it’s actually an I&L clone with the button. Do you guys have any advice on how to deal with the windshield wipers?
I searched the threads and could’nt find anything on it specifically.
Thanks in advance!
Old Dec 1, 2018 | 08:24 PM
thomsonac's Avatar
I don't remember the exact sizes- whatever I stuck into Amazon/AutoZone's sizer works just fine size/connector-wise. That said, do not(!!!) by the Bosch Icon wipers. They streak, they chatter, and they're loud. Honestly, I wish stock OEM wipers were available for purchase.
Old Dec 3, 2018 | 09:08 AM
ololly's Avatar
Stock OEM wipers are available at your local dealership. Ironically they cost only couple bucks more than IKONs. I replaced them with IKONS and had to go back to stocks.
Old Dec 16, 2018 | 08:38 AM
RGT's Avatar
RGT
Default Stock wipers hop
First rainy day for my new 2018, XF and my wipers are skipping, hopping and squealing all across the windshield. 30 minutes of driving in the rain was pretty annoying that way. Anyone else experience this? Is this just normal break-in? Haven't had this on any other car.
Old Dec 16, 2018 | 11:03 AM
madgrey's Avatar
Yes, same story here. First rainy day with my new XF (back in September) and I couldn't believe the noise. The dealer replaced the blades after I tried several fixes. New blades solved the problem, but they still squeak a bit at the end of travel from time to time. I can't remember ever having noisy wipers, in any car, that didn't have an obvious issue. The XF had me stumped.
After hearing this complaint a few times, I'm wondering if there's a design (or manufacturing) issue with the wiper arms. Maybe it's a tension thing. Is there a service bulletin?
Old Dec 18, 2018 | 12:11 PM
RGT's Avatar
RGT
Maybe when I'm picking up my plates I'll have them take a look.
Another wiper related issue that came up for me: apparently you can't leave them up in service mode. When it snows heavily, especially when going north for a ski trip, and I know it's going to be snowing overnight, I always lift the blades off the windshield. In this car, that's not an option. When ignition is off, they will always return to parked position out of service mode.
As I type this, I'm thinking that the Jag comes with a heated windshield, so maybe it's not something I need to think about anymore. First heated front windshield for me
Old Dec 18, 2018 | 01:14 PM
clubairth1's Avatar
Community Influencer
It might have heated wiper rests?
My 2005 S Type R had them. So no heated windshield but had some colored horizontal lines in the windshield down where the wipers rest.
Old Dec 18, 2018 | 03:21 PM
ololly's Avatar
I only use it to remove fogging out of mine. Not sure if it is strong enough to heat the outer surface quickly,
Old Dec 18, 2018 | 03:32 PM
Brutal's Avatar
Stock are way better than most anything out there. And theyre about the same price and unclip without adapters needed. Take 30 seconds to change both. Just about every aftermarket out there is also not stiff enough at highway speeds. And chatter, plus the oem come with a 1 year warranty
Old Dec 18, 2018 | 03:47 PM
RGT's Avatar
RGT
That's an interesting thought. I realized that the manual, which I actually RTFM'd fully, appears to not actually note what's optional equipment. So some things I find that I have and some I don't. The manual talks about every item as a given. The sales 'sticker' notes most, but not all options the car came with, so I guess some are 'Jag standard' and I'm just not familiar enough yet.
Old Dec 19, 2018 | 10:47 AM
clubairth1's Avatar
Brutal can you give some part numbers?
Looking around I find several and it's not clear which ones are for the XJ?
They are listing the F-Type but maybe they are the same?
Old Dec 20, 2018 | 08:55 AM
ololly's Avatar
When I was buying my OEM wipers at the dealership they asked for a VIN. Apparently there are some variations even within a model year. The tech said that he needs last 4 of my VIN to locate the proper wipers and there are several for my MY
Old Dec 20, 2018 | 08:59 AM
Brutal's Avatar
You know i dont work in parts
you need the last 6 of the vin not 4
there are online dealers that you can get part number access and the better ones will let you input you last 6 of the vin
Old Dec 20, 2018 | 09:06 AM
ololly's Avatar
Actually I didn't know that. Now I know
But now you know that I really don't work in parts
Old Dec 21, 2018 | 02:18 AM
Since Jaguar moved to generic manuals with one per Model per Model Year, this caveat has been in the Introduction:
I agree that a list of STANDARD and OPTIONAL equipment should be included.
Old Dec 21, 2018 | 10:37 AM
Brutal's Avatar
You know sometimes i just want to put an emoji on a comment not a thanks. Aka facebook style.................. Beuller, bueller, bueller
Old Dec 21, 2018 | 02:20 PM
ololly's Avatar
So true
Old Dec 21, 2018 | 08:38 PM
RGT's Avatar
RGT
So two more rainy days and the wipers are now working without a single skip or squeek. Either they broke in, or maybe there was some kind of wax on the windshield that needed to bring scraped off?
Old Dec 21, 2018 | 10:40 PM
mleskovar's Avatar
Here's my $.02..... I've had cars that the wipers 'stutter' and I've always been able to fix them after going through the drill .... blade angle, arm pressure, clean windshield (not just wipe but clean with razor blade and compound), and new blades. Never the same thing fixed the problem from one to the next but I have noticed that new blades on a clean windshield usually works for a while. I have also noticed that when lubricated with windshield washer fluid the stuttering stops for at least a while. Leads me to believe it's wiper blade rubber that's breaking down with use and airborne contamination that causes it.
Old Dec 22, 2018 | 10:34 AM
Brutal's Avatar
Originally Posted by rgt
so two more rainy days and the wipers are now working without a single skip or squeek. Either they broke in, or maybe there was some kind of wax on the windshield that needed to bring scraped off?
jaguar has a windshield paste that cleans the glass and should be done a often as needed. And im sure there other glass cleaning compounds out there as well. I know amway sells a glass cleaning paste that works the same too. I usually just use glass spray cleaner and 0000 steel wool faster and cleaned the crap off the glass you dont see
