XF (X260) 2015 onwards
XF climate control
Old Feb 27, 2022 | 11:39 AM
lindsayxf's Avatar
Default XF climate control
Hi
I have a 2013 XF 2.2 diesel. The vents stopped opening the other night. I googled reasons for this and low battery was the main answer so I trickle charged the battery. The stop start is now working again so the battery is fully charged but the vents still won’t open and the fan won’t come on. The outside temperature reads as blank on the climate control. Have also tried disconnecting the battery which made no difference.
any help and suggestions appreciated.
Lindsay
Old Feb 27, 2022 | 12:17 PM
lindsayxf's Avatar
See below
Old Oct 23, 2022 | 02:53 PM
jhutley's Avatar
Hi, did you manage to get a fix for this? Mine is doing exactly the same (2014 XF S 3.0D). I suspect the battery, but would be nice to get some confirmation before spending the money on it.
Old Oct 24, 2022 | 06:18 AM
lindsayxf's Avatar
It’s best to get the fault codes read. My problem was with the central fuse board in the drivers footwell. Corrosion in this caused by water from the screen washer pump.
fuse board replaced and water pump for screen washer replaced. Cost £1250 at Sandeman’s Forfar. Fuse board was £575 then VAT on top!
Car now running like a dream.
Hope this helps.
Old Oct 28, 2022 | 06:08 AM
nicktee55's Avatar
Hi, you're actually in the X260 forum (MY 2015 onwards).
There's a X250 forum on this site where you may get more answers.
John8
Apr 24, 2025 08:48 AM
TurboDave
Nov 27, 2023 02:58 AM
Ashy67
General Tech Help
Oct 22, 2021 05:36 PM
johnnywishbone
XF (X260)
Nov 19, 2019 09:09 AM
Sanpedro
Jul 26, 2018 09:08 AM
