XF (X260) 2015 onwards
XF-S Hesitates to start?
Old Jun 19, 2016 | 08:26 PM
BlackPack's Avatar
Default XF-S Hesitates to start?
Past few weeks have noticed on occasion (seems unpredictable) the car *almost* starts when the START button pushed, but then quits. After 2-3 more attempts, it starts as expected. Kinda like a lawnmower (not a compliment).
Have tried depressing the brake pedal more firmly; have tried ensuring driver's side door fully closed/engaged before starting; have tried fastening seatbelt prior to starting. No set pattern.
Anybody else experience anything similar?
Old Jun 19, 2016 | 08:28 PM
BlackPack's Avatar
And yes, have also tried holding down the START button longer...
Old Jun 20, 2016 | 10:08 PM
Magnumforc's Avatar
I wrote about this awhile back. You only touch the start button very briefly when holding down the brake pedal and it will start by its programmed sequence. I had the same problem and found that if you hold the start button for more than perhaps less than a second the vehicle will shut off immediately after almost starting. Mine did it three times in a row and I thought there was something wrong. But no, just the wrong touch.
Old Jun 21, 2016 | 12:22 PM
BlackPack's Avatar
Aha - makes sense, the circuit is probably thinking I'm trying to 'STOP' again by holding the button down. Thanks for the advice!
Old Jun 21, 2016 | 05:16 PM
carzaddict's Avatar
thats some really bad programming going on there. glad it got sorted
DJS
May 23, 2017 04:37 PM
Woznaldo
Jul 20, 2016 02:24 AM
Billy Syeon Harsh
Apr 11, 2016 07:31 PM
byjosh
Apr 5, 2016 08:05 AM
cbornet
Mar 30, 2016 08:35 AM
