“Transmission fault”
Old Feb 8, 2019 | 03:30 PM
Usiel Duran's Avatar
Default “Transmission fault”
I have a 2010 jaguar XFR with 64,000miles , while driving it the car just accelerated itself and did not move up speed just started revving , I had to park **** it down and turn it back on , and it drove good again what would be the problem ? The “transmission fault” warning came up
Old Feb 8, 2019 | 08:06 PM
Supercharged81's Avatar
There was a firmware/software update required for the transmission on some of the XFs of that era. Has the transmission been behaving erratically, slipping etc, other than this 1 occurrence?
Old Feb 9, 2019 | 01:41 AM
Bigg Will's Avatar
I'd get a scan done to find out what the fault was, serious trans faults will usually code out even on low level OBD 2 scanners then ensure the battery is good. And this trans (ZF 6HP28) does require regular maintenance, and is very reliable.
ooblick
Sep 19, 2019 11:32 AM
xtypejag502
Aug 27, 2016 09:18 AM
Sphillipss
36
Jan 4, 2015 08:52 PM
merlin637
Jul 16, 2014 12:44 PM
