0116 code
Old Aug 23, 2018 | 03:12 PM
jakesdad's Avatar
Default 0116 code
I got a recent code on obd 0116 which stated something to do with coolant electrical signal blah blah. Coolant level is ok and engine temp seems ok No other issues with coolant.
side note,,,I've also recently started getting the beloved 0171 and 0174 with cel, but the fuel trims both stft and ltft are not high and are not misbehaving from what i can tell. why the lean codes if trims ok?
Old Aug 24, 2018 | 11:55 AM
JagV8's Avatar
Check ALL the meanings of the code - it's probably one of the others.
Get the freeze frame data for the lean codes for more clues.
Old Aug 24, 2018 | 09:14 PM
jakesdad's Avatar
thanks jagv8...you may recognize me from the lean code problems i had on the s type. I forgot to mention this is now on my 09 xf 4.2
(s type 3.0 was resolved)
Old Aug 28, 2018 | 10:02 AM
jakesdad's Avatar
Jagv8.....I am uncertain how to pull and interpret freeze frames, but I am trying to learn. I did locate the freeze frame on my torque app and opened it and saw some exceptionally high fuel trims on both banks (moreso on bank 2) I guess when the faults logged.
Wife is driving this car and reports no cel on morning drive (cooler outside temp) but the cel is coming on shortly after driving the car a few miles during the return trip in the afternoon.
I need to better understand how to fully utilize the obd reader. for past few years, I've only used it to read codes.
for now, I think I am going to try some BK 44 and see if it has an effect. Maybe the injectors are a bit fouled. I sure don't want to go thru another lean code battle that I endured with the s type. I don't think I have the stamina for it.
Old Aug 28, 2018 | 01:24 PM
Brutal's Avatar
Look at the secondary air vacuum lines theyre the most common for that issue on your car. Thyre plastic and brittle. Replaced all the vacuum lines avail from jaguar
Old Sep 11, 2018 | 11:06 AM
jakesdad's Avatar
Brutal...I tried a new air filter and maf sensor(I got a mafs fault code) but to no avail. Still getting 0174 and 0171 each day but only on the afternoon commute as if ambient temp is in play?
frankly I have to admit that my years long battle with lean codes on the s type wire me out. This 4.2 is very intimidating to me. Can't even see coils. I'm not sure specifically which vaccuum lines you refer to and kinda afraid of it. I'm thinking of changing the fuel filter but beyond that, I might be dealer bound. This is the car that cost me $5,000 recently when I changed the battery and blew up the whole thing. Instrument cluster, anti theft module, fuse block....this is a car that I will never disconnect battery again except at dealer. Thinking if they blow it up, maybe I have recourse. So beyond only the simplest diy items the car is beyond me.sadly.
Old Sep 11, 2018 | 04:49 PM
Brutal's Avatar
lots of stuff can lean codes on the 4.2 which is why I spray them with brake clean while monitoring short term fuel trims and also smoke test. cam covers leak, oil dipstick oring, intake gaskets, plastic vacuum lines and loose or leaking air intake tube between the throttle body and mafs. etc The other big issue is where the plastic and metal intake(hold inejctors) manifolds meet. There are orings inside that jaguar does NOT sell, But Land Rover does same part
chazaroo
Sep 17, 2020 04:09 AM
pastor
Oct 23, 2017 04:36 PM
carcster
Sep 29, 2016 02:21 AM
MBary
19
Jul 17, 2013 02:30 PM
christer200
May 14, 2009 04:40 PM
