How do I identify my cams?
Hope you guys can provide a little help. I inherited a 2011 XFR 5.0 SC recently. The person who owned it passed away in the middle of a repairs. Unfortunately, I received the vehicle with the cylinder heads off and disassembled - all of it unmarked. I think I figured out which heads are left and right but I'm having trouble identifying the cams. I did find a little info but I want to be sure. A friend who is a Ford enthusiast gave me this this morning. I understand the Jags use ford engines but would the setup be any different in a Jag?
Drivers head
YF3E 6A273 AB exhaust
YF3E 6A271 AB intake
Pass head
YF3E 6A270 AB intake
YF3E 6A272 AB exhaust
Drivers head
Pass head
It's not a Ford engine, it was 100% designed by Jaguar, but it was and still is built in the Ford engine factory at Bridgend in Wales and uses quite a few FoMoCo stamped parts.
Get a copy of the 2010-2011 XFR Workshop Manual from my Dropbox here: https://www.dropbox.com/s/bet26xniua...kshop.pdf?dl=0
Also the AJ133 SC technical training doc here: https://www.dropbox.com/s/8y4iax9hm2...%20V8.pdf?dl=0
One or other of these should help with the rebuild.
Your cams should not -AB on the end of the stamped number.
But the 6A27x appears to be the same identification for inlet/outlet, LH/RH bank.
For example.
5.0L S/C with Tsubaki chain system
LH B-Bank inlet camshaft
AJ811993, 9W83-6A271-AD
For example.
That is what is on the cams though. I looked at some pics I took but they don't show it well enough. I'll take some more tomorrow and post a link to them. Thanks for your help!
Thanks again for this info. I am not with the car yet to check for the AB stamp. I reviewed the pics I took but they weren't good enough to tell. Would you be able to confirm with these numbers that what I have for the LH/RH & IN/EX is correct?
Drivers head (LH in USA)
6A273 AB exhaust
6A271 AB intake
Pass head (RH in USA)
6A270 AB intake
6A272 AB exhaust
viscoussquirrel
Mar 2, 2010 02:57 PM
