09 xf. How to add transmission fluid?
Only had for 2 months and my check engine light came on, the code p0411 and p0128 r pending codes, it said primary fix was replace secondary air injection valve vacuum hose , parts needed was transmission fluid, Also, replacement of the asv. Parts r thread lock,. Now that i have said parts, where do i add the fluid? As well as the thread lock?
