2009 XF coolant bleed screw?
Old Sep 9, 2020 | 12:11 PM
dotcom's Avatar
Exclamation 2009 XF coolant bleed screw?
Hi,
Changed the coolant expansion tank because of a broken nipple. I can't get the air out of the coolant system. I've tried running with heat on and pumping the hoses. Can't get the cabin heat up. The expansion tank stays full. Car over heats if driven. I don't see a bleed screw on the passenger side lines. Any help appreciated.
Old Sep 10, 2020 | 04:52 PM
Six Rotors's Avatar
The coolant bleed screw is on top of the coolant expansion tank and should be open before you start adding the new coolant.
Old Sep 11, 2020 | 05:23 PM
POD XF's Avatar
On the supercharged model the bleed screw is on the end of a little hose that sits at the right-hand end of the radiator.
Old Sep 11, 2020 | 09:32 PM
Six Rotors's Avatar
True but dotcom's car is a 4.2L NA , according to his Profile.
Old Sep 12, 2020 | 07:57 AM
dotcom's Avatar
Default funnel
I went with this Lisle radiator funnel and it seems to have worked. Is the bleed screw next to the nipple on top? It looks very fragile.
Old Sep 12, 2020 | 01:43 PM
Six Rotors's Avatar
Yes that's it---gently with a big screw driver. I have a the same funnel needed when I had Mazda RX7 Turbo II and Twin Turbo.
deftone
Sep 6, 2024 04:07 AM
TGon
Jun 24, 2017 01:10 PM
jag79
16
Jan 17, 2015 11:50 PM
Rique
Oct 23, 2012 09:30 PM
derby98
Jul 17, 2012 11:46 AM
