2009 xf key fob replacement help!!!
Received 2,184 Likes
only if the car was broken into when armed is this the issue. So your dog chewed but have you opened the door with the spare key in the remote, and the remote may not work passivly but may still be working by holding to the reader and starting
The following 2 users liked this post by 2kry4:
Cambo (01-11-2019),
thistle4celtic1 (04-22-2021)
Was in a car accident in my (non-jag) car and my 2011MY XF key fob was ejected from my set of keys in ignition and broke into many pieces.
I just got back from the wreckers where I retrieved pretty much all the bit 'n' pieces and put it back together (minus the chrome strips on either side) with glue and rubber bands, a la Humpty Dumpty.
All the buttons seem to "click" as they should. I replaced the battery as the fob sat for three days in pieces. The (-ve) tab is in the right spot/slot to make contact with battery.
Car doesn't respond to any of the five buttons when I push them, so I had to use metal key to get into car.
Of course, the alarm sounds right away (for 20secs or so) as the car can't see the fob...as per message on dash..."Smart Key Not Found".
I haven't tried putting the fob in the slot below steering wheel to see if it recognises it that way. Guess I'm not sure if I'll be able to get it back out of slot.
Anyway I guess my question is: Since the fob sat in pieces for days, is there something that has to be done to "remarry" the fob to vehicle?
...and if not, does anyone have any other suggestions before I look into getting TWO new key fobs made.?
Thanks for any help
Thanks for any help
Glad it worked out for you, i had 1 key when i got my car, i boght one of aliexpress for 40 bucks and a obdstar h100, programmer for 80 bucks on AliExpress too.
That thing worked like a charm programmed my key in less than 1 minute, very easy to use instructions on screen.
Although I had 1 key already it has an option for program from cero keys, wasn't able to test it but it should work.
Hmm....I think I will invest in that same package deal that you got from Alibaba.
FWIW....The car "sees" the fob when it's docked (and car will start), just not when the fob is used as standalone.
So, for now, I can't lock the lock unless I want to use the metal key every time I want to unlock door.
#28
https://www.jaguarforums.com/forum/x...0/#post2302560
thistle4celtic1 (04-23-2021)
Thanks for any help
Thanks for any help
thistle4celtic1 (04-27-2021)
#30
Thanks Carlos, bealz and kansanbrit.
Key fob is still held together by rubber bands until the new cases I ordered get here,
I put a new battery in and took special care to make sure the tab on circuit board is contacting battery.
Weird thing is the fob still won't work by itself, but luckily it does when docked, so I can still start and drive the car in the meantime.
Just won't lock it as the fob won't unlock the doors.
#32
#33
I checked the voltage of the new battery I put in and it's good. I'll take your advice and drop by O'Reillys
#34
Still waiting on the OBDSTAR 100 to arrive from China.
Out of curiosity I called the closest Jaguar dealership and they quoted $405 for the genuine Jag key fob and $185 to program it.
Technician did ask if the car started when "docked", as he did say it gets way more expensive with no good fob to start with.
Any suggestions as to what's the better choice for a key fob to program. New knock-offs on EBay run around $55, whereas used genuine fobs go for $75.
Maybe I'll buy one of each?
#35
thistle4celtic1 (05-11-2021)
#36
#37
Correct, used 09-12 fobs cannot be re-programmed, good that there is a reasonably priced aftermarket option now.
If any of you are finished with the Obdstar H100, maybe we can split the cost of the thing if you forward it to me. Seeing as its something used just once it would lower the replacement cost even more to pass it along.
#38
thistle4celtic1 (05-13-2021)
#39
I thought they might be as the ones offered on EBay suggest they're ready to be reprogrammed.
Surely they're not being sold as paperweights.
I ordered one of each (a genuine used and a knock off) and will report the outcome after they and the OBDSTAR100 arrive.
#40
Make sure your fob is transmitting, as suggested earlier, the device must be able to communicate. If it's not picking up the battery check the contacts, you might have to resolder, it's farely easy.
Last note there's a part where the obdstar 100 asks for, immobilize/fob type. I used type 1.
