2009 XF SC - getting check engine codes P2402 and P2406
Old Dec 19, 2014 | 12:05 AM
blaydes99's Avatar
Default 2009 XF SC - getting check engine codes P2402 and P2406
In the past month or two, I started getting the check engine codes P2402 and P2406, which are "Evaporative Emission System Leak Detection Pump Control Circuit High". I cleared the code(s) and they come back after about a week of daily driving.
I did some reading online and didn't find much, but did find that this may be due to a DMTL pump issue of some type. Either that or the canister/tube connected to the pump? Has anyone had a similar issue or have a diagram on where this is located?
DMTL: Diagnostic module fuel tank leak (DMTL) pump
Old Jun 23, 2016 | 04:53 PM
blrx7r1's Avatar
I just got the same thing. No idea what it is.
Old Jun 24, 2016 | 12:22 AM
JagV8's Avatar
Search will get you other threads. It's likely the pump. Could be its wiring/connectors (check fuses/relays of course).
Old Nov 30, 2016 | 09:29 AM
bmcinsd's Avatar
This code has been showing for the past two weeks. Anyone have any insight into what might be causing it?
Old Nov 30, 2016 | 11:56 PM
bmcinsd's Avatar
I think I found the culprit. Might anyone have a diagram to where the Fuel Vapor Canister is located - part #C2D40532? I think it might be on the Fuel Tank itself.
Old Mar 22, 2017 | 01:24 AM
moe's Avatar
moe
was it the canister? is it fixed now? where is it located. having the same issues
Old Aug 3, 2017 | 02:15 PM
bmcinsd's Avatar
Any updates? About ready to buy the fuel vapor leak detection pump to see if that fixes it.
Old Aug 3, 2017 | 03:16 PM
moe's Avatar
moe
yah buy it... it will fix the problem
Old Aug 4, 2017 | 06:40 AM
S-Typer's Avatar
Had the same code on my XK for a while. I found that pump can be purchased off eBay separately (Land Rover part). Cost was under $100 for part. Local mechanic changed it out for under $120.
Fixed the light and the code never came back.
Joe
Old Aug 4, 2017 | 12:33 PM
bmcinsd's Avatar
Do you happen to have the part number for the Fuel Vapor Leak Detection Pump? I have been searching and can't find it anywhere. I have a 2012 Jaguar XFR. I assume the same pump would be found on an XF.
Old Aug 5, 2017 | 07:28 AM
S-Typer's Avatar
WTR500030. There's a good deal on eBay right now.
Joe
Old Aug 14, 2017 | 01:40 PM
bmcinsd's Avatar
Joe
Trying to cross reference it with the 2012 Jag XFR. Does anyone know if this leak detection pump work for the '12 XFR.
Old Aug 17, 2017 | 10:35 PM
cjatx's Avatar
I'm getting a PO2402 code with my 2009 XF SC.
I have a shop manual. It doesn't refer to an evaporative leak detection pump, but does show a tank leak detection pump that connects to the charcoal canister. Are these pumps the same thing?
In the manual, the first step in removing the charcoal canister is to remove the differential. This seems like a lot of work to access a maintenance item like the pump.
Am I understanding everything correctly?
Thanks,
Chris
Old Aug 17, 2017 | 11:10 PM
S-Typer's Avatar
Thanks,
Chris
The Jag Manual will tell you the whole canister needs to come out as they do not sell "just the pump".
That part number I mentioned earlier is the exact same pump as the 4.2 (maybe 5.0's too) car. It's sold under Land Rover and bolts right in. No need to mess with differential (at least on XK). Local shop said it was no big deal and charged an hour. You can get under car and look in front of gas tank and see the pump (wire harness is connected).
Joe
Old Aug 18, 2017 | 06:47 AM
cjatx's Avatar
Joe,
I appreciate your input. I've uploaded pages from the manual. On the XF, it appears the pump is connected to the canister and right next to it behind the gas tank. There are no instructions for removing the pump, only the canister.
I'm hoping someone on the forum has experience with this.
Thank you,
Chris
Old Aug 27, 2017 | 09:12 PM
bmcinsd's Avatar
Joe,
Thank you,
Chris
The guys at my shop just told me the whole rear sub-frame needs to come down....yikes...Is this true? The pump only costs $120...labor?
Old Apr 21, 2018 | 10:30 PM
ajkc's Avatar
Got the same 2 codes - 2402 and 2406 - you can buy the pump separately as mentioned. I have a 2010 XFR with electronic differential- NO access to valve because of electric motor - have to drop differential or heaven forbid cut an access hole in the trunk floor.
Old Dec 29, 2020 | 04:36 PM
bmcinsd's Avatar
Hello All,
I still have these 2 codes - P2402 & P2406 - Has anyone recently replaced the pump? Do you really need to drop the rear sub-frame?
fast40driver
Apr 19, 2024 07:24 AM
philwarner
Dec 6, 2021 07:13 AM
Thempsc
Sep 7, 2015 02:29 AM
NMichXKR
Sep 2, 2015 12:32 PM
daro31
Aug 27, 2015 09:26 AM
