2009 XF trunk won’t open
Old Oct 27, 2018 | 08:32 AM
Fharon's Avatar
Default 2009 XF trunk won’t open
I closed my trunk the other day and drove home. When I arrived I noticed the truck indicated it was still open. I got out and the trunk is closed. Any ideas why it would indicate open. This keeps my smart key from being able to lock the car. I thought it might be a fuse but unfortunately I can’t determine which fuse; the owners manual doesn’t specifically state “trunk fuse”. I need some help please.
Old Oct 27, 2018 | 10:32 AM
BritCars's Avatar
Most likely the wiring harness that connects the lock, lights etc in the trunk lid. If you open it (might need to do so manually using emergency key blade - see user guide) there is a rubber boot near the right hand hinge. Pull it back (you might need to cut a small rubber piece to get it to slide back) you'll prob find one or more of the wires are frayed / broken. You can easily splice if you're handy, else a new harness is probably $100 or so
Old Oct 27, 2018 | 11:04 AM
Fharon's Avatar
Looks like I may be in trouble. I can’t get the emergency key to open it.
Old Oct 27, 2018 | 02:03 PM
Calif XFR's Avatar
Same thing happened to me about a month ago. When I was using the key, I needed to push down on the trunk while turning the key - and it opened. Ended up being the infamous broken wire in the wiring bundle. Easy fix (solder and heat shrink) - and reinforced the other wires. Good luck.
XJL2011
Sep 19, 2024 01:06 PM
tnt
May 23, 2022 07:30 PM
dorothysplayhouse
Sep 26, 2017 10:36 PM
MrJagXJ
Sep 15, 2013 06:32 PM
