2009 XF trunk won’t open
I closed my trunk the other day and drove home. When I arrived I noticed the truck indicated it was still open. I got out and the trunk is closed. Any ideas why it would indicate open. This keeps my smart key from being able to lock the car. I thought it might be a fuse but unfortunately I can’t determine which fuse; the owners manual doesn’t specifically state “trunk fuse”. I need some help please.
Most likely the wiring harness that connects the lock, lights etc in the trunk lid. If you open it (might need to do so manually using emergency key blade - see user guide) there is a rubber boot near the right hand hinge. Pull it back (you might need to cut a small rubber piece to get it to slide back) you'll prob find one or more of the wires are frayed / broken. You can easily splice if you're handy, else a new harness is probably $100 or so
tnt
05-23-2022 07:30 PM
dorothysplayhouse
09-26-2017 10:36 PM
MrJagXJ
09-15-2013 06:32 PM
Mccalist
12-14-2009 09:05 AM
