2010 XF premium 5.0 repair manual
Old Apr 22, 2018 | 09:46 PM
Mike shea's Avatar
Default 2010 XF premium 5.0 repair manual
hello I just finished up a weekend project of replacing the water pump on my 2010 XF 5.0 premium sure wish I had a good repair manual. Could someone point me in the right direction of what repair manual to buy. I am NOT a mechanic but do not mind getting my hands dirty and learning a few things to boot. I have looked on line only to find about 50 different on line manuals but I have no idea just how well they are written or illustrated. I’m sure the investment in a high quality manual would be well worth the cost seeing as Scottsdale Jaguar wanted over $1,200 to replace my water pump and I was able to replace it for the cost of the part and some long life coolant ($ 150. Total) and one weekend
thank you fellow Jag owners
Old Apr 22, 2018 | 10:51 PM
OzXFR's Avatar
You can download a copy of the 2010-2011 XFR Workshop Manual from my Dropbox here: https://www.dropbox.com/s/bet26xniua...kshop.pdf?dl=0
This is the official factory manual and although it's for the XFR it also covers the 5.0 NA.
Old Apr 23, 2018 | 01:02 AM
Mike shea's Avatar
OxXFR thank you very much that manual is fantastic.I wish I would have asked for help earlier I spent hours looking for a way to bleed the coolant system of trapped air and the manual had a pic of the location of the bleeder screw right where I didn’t look. I bet I could take the whole car apart and put it back together with all the information you supplied well maybe I’ll just read through it and figure out my next project the disk brakes. Thank you again
Old Apr 23, 2018 | 01:40 AM
OzXFR's Avatar
The brakes are easy, I have replaced rotors and pads on both the XFR and the F-Type (same brakes other than the EPB) twice each.
Old Apr 23, 2018 | 07:55 PM
BritCars's Avatar
There is a great 'how to' here on the XF forum for replacing the brake pads and rotors all round. With pictures too. I followed it to do mine and it was easy
Explore aftermarket ceramic pads if you want a much lower dust.
You need a tool to screw in the rear brake caliper piston - I just bought it for 30 dollars or so online
Old Apr 24, 2018 | 03:35 PM
Mike shea's Avatar
Thank you again I’ll check it out
Old Apr 30, 2018 | 01:50 AM
Ebbie1's Avatar
Can this manual be used for the 2010 Jaguar XF model as well?
Old Apr 30, 2018 | 02:01 AM
OzXFR's Avatar
It's specifically for the 2010-2011 XFR and also covers the 5.0 NA so it will still cover 99% of things on your car.
Old May 25, 2019 | 09:21 AM
PJ704's Avatar
Do you recommend aftermarket pads and rotors? Also, are you talking about something like this for the rear brake caliper piston?
https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds
Old Jun 6, 2019 | 01:08 PM
wagerssm's Avatar
Oz im planning the water pump this Friday do i access from the top or bottom?
Scott
Old Jun 6, 2019 | 02:53 PM
Mike shea's Avatar
Scott
Scott I had no problem doing all of the work from the top.Repacing the water pump was a fairly easy job.
flynnaaron
May 4, 2024 07:14 PM
jimlombardi
Jul 18, 2014 07:17 PM
JaguarXKR
Feb 10, 2013 11:10 AM
srichhaya
Oct 19, 2009 05:40 AM
