2010 XFR Brake Pads
Old Mar 18, 2013 | 08:09 AM
edobernig's Avatar
Default Regarding rattle clips
Will,
That's a bummer. Personally I would find a set, because they are there for a reason. As I remember, I reused the original clips because the ones they supplied did not fit as well. That maybe the reason they fell out. Can you find your old ones and re-install them? Quick before the trash gets picked up,otherwise Brake Labs could send you another set.
Old Mar 18, 2013 | 06:52 PM
macboots's Avatar
Originally Posted by edobernig
Will,
Came to the same reasoning you did... obviously someone put them there for a reason.
I had reused the old ones, so I dug through the trash and found the new ones and installed them today.
They seem fairly snug. Hopefully they stay on this time!
Cheers,
- Will
Old Mar 18, 2013 | 07:26 PM
jagular's Avatar
They are there exactly for the reason they are named for. Not all brake pads will rattle but they likely will at some point. Braking efficacy will be unaffected either way, these are noise reducers. If it were my car I'd get a replacement set and install them.
Old Mar 19, 2013 | 07:58 AM
edobernig's Avatar
Default Always save reusable parts for a while
Cheers,
- Will
Lucky! Now you're an expert. I usually save the reusable parts for a while just to be safe and trash them when I forget what they were for.Good thing your're in FL, yesterday 2" of snow and this morning 17 F here which is not so nice for brake service.
Old Mar 19, 2013 | 08:01 AM
jagular's Avatar
So I'm not the only one who saves old parts for a while. For me it's superstition!
Old Apr 3, 2013 | 05:17 PM
Johnny Vig's Avatar
Great info in this thread. I need to replace my back brakes at 20k, but I am just doing the pads and not the rotors. Figure I will do the fronts as well while I am at it.
Can you guys give me an idea of how you like the ceramic pads? Low dust i assume and how do they brake? Did u lose stopping power? Thanks in advance.
Old Apr 3, 2013 | 06:06 PM
jagular's Avatar
You will likely regret not doing the rotors at the same time.
Old Apr 4, 2013 | 07:54 AM
  #28
macboots's Avatar
My experience in the past several weeks are the ceramic pads produce about 1/4 the brake dust of the stock pads. With the stock pads, driving primarily to/fro work (10 miles each way city driving) my wheels would look like I drove through mud after about 3 or 4 days...
Stopping power seems unaffected. Don't know how they would react to fade on a track, but certainly good for street use. They are also less grabby than the stock pads.
Cheers,
- Will
Old Apr 4, 2013 | 07:56 AM
edobernig's Avatar
Default Check the write up in the "How TO" Section regarding brakes.
Ceramics work fine. Read my post in the "How to Section" it covers just about everything. https://www.jaguarforums.com/forum/x...job-how-85582/
Old Apr 5, 2013 | 04:18 PM
  #30
john501's Avatar
looking for good brake pads and rotors front and rear...any suggestions re your experiences..
John
Old Apr 6, 2013 | 11:32 AM
  #31
macboots's Avatar
Ed's faq listed above covers it all, including sourcing for pads and rotors...
Cheers,
- Will
H20boy
Dec 24, 2024 03:23 PM
raulan
Sep 10, 2015 12:43 PM
1964Daimler
Sep 9, 2015 11:28 AM
Mike Green
Sep 7, 2015 12:39 AM
JagLove86
Sep 6, 2015 10:36 PM
