2013 XF Engine Defrost Plug?
Old Oct 7, 2013 | 01:21 PM
Kristin_w's Avatar
Question 2013 XF Engine Defrost Plug?
Has anyone ever heard of a "frost plug" on an XF engine? Something that, if loose, would cause engine oil to leak out? Like, all of it? If you know, where is it and what is it for?
Last edited by Kristin_w; Oct 7, 2013 at 01:25 PM. Reason: Frost plug, not defrost
Old Oct 7, 2013 | 02:50 PM
JonnyJag's Avatar
I think you mean freeze plug. It is for the coolant.
A true freeze plug is an expansion plug located in the side of an engine block that is supposed to protect the block against freeze damage. Water expands when it turns to ice, and if the coolant does not have enough protection it can freeze and crack the engine block. The freeze plugs (there are usually several) are supposed to pop out under such conditions to relieve the pressure on the block.
Old Oct 7, 2013 | 03:01 PM
Kristin_w's Avatar
So...this would have nothing to do with oil leaking out of the engine, am I right? Coolant, yes, but not oil?
Old Oct 7, 2013 | 03:03 PM
DPK's Avatar
DPK
Yes..Nothing to do with Oil..only coolant (antifreeze).
Old Oct 7, 2013 | 04:35 PM
JonnyJag's Avatar
Now, if you lost the oil pan drain plug, this would cause all of the oil to drain to the ground.
D.K
Dec 10, 2023 02:05 AM
Gus
Oct 15, 2019 12:29 PM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 2, 2015 12:48 PM
XJsc-guy
Sep 2, 2015 11:43 AM
