2014 XF 3.0 weirdest HID problem
Old May 3, 2023 | 12:07 PM
Macs39's Avatar
Default 2014 XF 3.0 weirdest HID problem
__________________
2014 XF 3.0 Supercharged (145000 Mild Km ; always in the family)
The right side (passenger-side) Low and highbeam not working. Change of bulb and ballast did not make any difference. But further investigation and stopping the light assembly they do work from the driver-side switch. Also work when the mechanic brother connecting wire from the driver-side positive for passenger-side switch. But when he connected both lights through the driver side it kind of flickered together for a second and then off again. With the multimeter can get 14 moulds on the blue-green while that's listed for the headlights.
ALL THE OTHER LIGHTS INCLUDING THE LEDS AND TURN SIGNALS WORK FINE ON BOTH SIDES.
No Codes whatsoever in the car OR Generic OBD Scanner
Logically I think it should be the HEADLIGHT CONTROL MODULE and I have ordered use one from eBay.
I would really appreciate any help because I don't want to be throwing parts at this anymore.
Old May 3, 2023 | 12:10 PM
Macs39's Avatar
Thanks. No Fault Codes on Bosh or Blue Driver OBD
Old May 3, 2023 | 02:14 PM
JagV8's Avatar
If there are codes they would be seen only in a Jaguar-specific tool (SDD etc).
Old May 3, 2023 | 10:19 PM
Macs39's Avatar
No Fault codes in the car either.
Old May 4, 2023 | 05:04 AM
Macs39's Avatar
Actually Jaguar dealership also did a diagnostic in Janauary this year and did not show any HID codes.
Old May 5, 2023 | 08:31 AM
Macs39's Avatar
Default Bringing this down with the hope to get some help
Old May 5, 2023 | 08:46 AM
JagV8's Avatar
You probably wouldn't get them from either of those, if there are codes for what you report.
Old May 6, 2023 | 03:28 PM
Macs39's Avatar
Brought back to top because prevous version had mistakes.
Help Needed
Left side is fine as before.
The right side (passenger-side) Low and highbeam were not working. Change of bulb and ballast did not make any difference. But further investigation and swapping the light assembly they both work through the driver-side switch. Also work when the mechanic brought a connecting wire from the driver-side positive to passenger-side just before the switch. But when he connected both lights assemblies;they both flickered together for a second and then off again. With the multimeter can get 14 volts on the blue-green (HIDpositive wire; that's listed for the headlights.)
ALL THE OTHER LIGHTS INCLUDING THE Ring LEDS AND TURN SIGNALS WORK FINE ON BOTH SIDES.
No Codes whatsoever in the car on Jaguar or Generic OBD Scanner
Logically I think it should be the HEADLIGHT CONTROL MODULE and I have ordered a used one from eBay.
Old May 17, 2023 | 12:50 PM
Macs39's Avatar
So I was finally able to fix the Right Side Headlamp issue and want to document it for others. I went through changing HID Bulb (I bought both sides), then the Ballast and also bought a HID Control Module. Also multiple visits to different mechanics and causing an additional problem with the central locking after I tried to hard reset by disconnecting the battery. A month later, I was able to run SDD for fault codes and got B1D01-15 (Right Low Beam Short to Battery or Open).
After getting to the HID Control Module, I finally found out that the problem was with the Module Pin Connector Not Sitting Properly in Its Socket.
So please check and wiggle this HID Control Module Pin Connector (under the passenger (Right side) footwell for American version) , before throwing money at the headlight assembly compnents.
John J.
Jun 3, 2025 05:18 PM
prolepsis
Jan 8, 2023 05:42 PM
hen555
Apr 7, 2018 10:32 PM
Duke26
Feb 12, 2015 04:21 PM
hawee
Aug 7, 2011 11:22 PM
