2015 XF 5.0 S/C Gearbox Fault.
Old Jun 12, 2020 | 07:09 PM
Enrique8250's Avatar
Exclamation 2015 XF 5.0 S/C Gearbox Fault.
Good evening fellas, I've had my vehicle as stated above for a couple of months. Long story short i drove through a heavy rain storm and left my vehicle parked outside. Water leaked into my vehicle and now i am getting a Gearbox fault issue. I tried using a blow dryer and it would sometimes correct the issue and she would drive normally. Other times (say later on in the day) she'll go back into Gearbox fault mode and wont let me change/select gears. I assume the TCM might have gotten wet? I appreciate the help and would rather not have to use a dealer if its an easy fix.
Old Jun 17, 2020 | 05:47 PM
Jssaab's Avatar
I know my transmission gearbox failure issue was caused by a bad battery and a corroded connection. Maybe water is interfering with the resistance of the electronics.
Old Jun 30, 2020 | 02:08 PM
F1Virginia's Avatar
Howdy..
Any updates on your transmission issue?
Thx!
dustin03xtype
Mar 1, 2020 07:01 PM
XFowner
Sep 24, 2019 03:16 PM
jaguarXFsupercharged_XFR 500HPclone
Feb 6, 2019 06:47 PM
bobo dioulaso
Aug 13, 2017 07:33 PM
NoHub55
Apr 29, 2016 10:59 PM
